2010-2011 spark plug wire retainer part#
FITZ
Momence, IL
Does any one know what the part # for the 2010-2011 spark plug wire retaining clip is? The plastic part that holds the wire and is attached to the cam covers by thin little studs. Thanks!
MTF
Celebration, Florida
fordracing.com/parts
Will have everything you need to find the # and or just order it.
Right now the site is down!
F
FITZ
Momence, IL
I'm looking into putting the 2010-2011 ford racing cam covers on my truck which is a 2014. Looks like the only difference is how the spark plug wires attach to the cam covers and the wire loom that runs across the engine on both sides also use the same type of connector. Was just seeing if I can find the part numbers or if this is a no go. Thanks
MTF
F
FITZ
Momence, IL
Ok, I messed up, it's Ford Parts not Fordracingparts. Sorry I'm on a computer now, I hope this is what your looking for.
Spark Plug Wire is the same part number# 12286
But there isn't a part number for the clips you are talking about, my best guess there shouldn't be a difference.
Click on Link: 2014 Ford F-150 Spark Plug Wire | FordParts.com The diagrams look the same to me for 2011: 2011 Ford F-150 Spark Plug Wire | FordParts.com
Thanks for the help, My guess is that the clips come attached to the factory plug wires. So I would need to order new wires for this to work. Then I still have no way to attaché the wiring harness that runs across the top of the cam covers.... I'm thinking there might be an awesome set of Ruby Red 2010-2011 cam covers for sale soon. Would probably look good on a black truck
BAJASVT
SE Michigan
Are you looking for the actual studs or just the plastic retaining clips that thread on to the studs and hold the wires? There are three on the passenger side and four on the drivers side.
F
FITZ
Momence, IL
Looking for just the plastic retaining clips that mount to the studs
F
FITZ
Momence, IL
It appears this isn't going to work. Looks like there going to the for sale section....Damn. Cause they look awesome.
