2017+ Raptor Shock Package!!!
Rogue Racing
$5799.99 shipped in the continental US! Front and Rear OEM replacement King shocks and a set of Rogue Racing 2017+ Raptor bushing UCAs!!! MSRP $7199.97!!!!
2017+ Ford Raptor
King Shocks 3.0 IBP Performance Series Kit
100% bolt on
Large 3.0” OD shock bodies
A true, full diameter piston and valve stack for maximum damping control
Fully able to rebuild, service, or tune
Finned Reservoir
Factory tuned for optimal ride quality
Material quality and tolerances to match our top race shocks.
Front
Large 3.0 mono-tube shock body
Patented “Internal Bypass” (IBP) technology
Compression adjuster
Reduces shock cavitation
30 clicks of compression adjustment
1” diameter shaft
3.5” OD finned reservoir
1 piece extrusion- not a sleeve
New hose attachment allows easy hose clocking
100 % bolt on
$3499.99 MSRP
Rear
Proven external bypass design
4 Bypass tubes
Position sensitive damping
Separate compression and rebound external adjustments
1” diameter shaft
2.95” OD finned reservoir
100 % bolt on
$2899.99 MSRP
ROGUE RACING HORIZONTAL 1" UNIBALL STOCK REPLACEMENT UCA - w/BUSHINGS FOR 2017 FORD Raptor
100% American Made
3D CAD Designed
Precision fixtured
CNC press broke Triangle construction
Corrected Length at +2 inch ride height
American Made 1” WSSXT Heat Treated Uni-ball
17-4 heat treated rust & corrosion resistant stainless steel pin and high misalignment spacers
Rogue Racing Proprietary bushing material silent ride and no chatter
Bushing service Zerk fitting
Countersunk 12 point zinc plated bolt
$799.99
Call 855-757-6483, DM or email [email protected] to place your order! ***Current lead time is 8 weeks***
Rogue Racing
Rogue Racing
Any real world feedback on increased performance over stock?
The OEM replacement Kings were excellent on our 2017 Raptor equipped with Stage 12 UCAs, LCAs, Spindles and HD Tie Rods. Check our Instagram story from yesterday for a sneak peek at some video footage from Lifted Life TV.
Big Johnson
Southern Alberta
I have the oem replacement Kings on my gen 1. Unbelievable ride, 100k hard miles and havent rebuilt them yet. Nothing rides like Kings
Rogue Racing
Rogue Racing
We are also adding the option for heim UCAs to this package!
$6299.99 shipped in the continental US! Front and Rear OEM replacement King shocks and a set of Rogue Racing 2017+ Raptor heim UCAs!!! MSRP $7899.97!!!! 20% off retail!!!
Call 855-757-6483 to place your order today!
