Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > ReadyLIFT Suspension
Ford raptor, 2010-2014, t6 billet 2.0" leveling kit
This is a discussion on Ford raptor, 2010-2014, t6 billet 2.0" leveling kit within the ReadyLIFT Suspension forums, part of the Ford Raptor Forum Supporting Vendors category!
Part Number: T6-2055-B -Keeps your factory ride! -Made In U.S.A. -Will never break or fail! -Durable custom anodized blue finish ...
Like Tree1Likes
  • 1 Post By ReadyLIFT Suspension
Old 02-21-2014, 06:39 PM   #1 (permalink)
ReadyLIFT Suspension's Avatar
Default Ford raptor, 2010-2014, t6 billet 2.0" leveling kit
-Made In U.S.A.
-Durable custom anodized blue finish (T6-2055B)
-10.9 grade mounting studs w/ nuts
-CNC machined billet aluminum construction
-T6-2055B - 2.0" of front lift
-Made To Fit Ford F150 Raptor SVT with 35" Tires
-Safest way to level lift your truck! - Guaranteed!
A steel construction Raptor Leveling Kit is also available
Also Available to lift the rear of your Raptor - 3" Rear Block Kit!
PRICE:
$249.95
AngryBird likes this.
ReadyLIFT Suspension is offline
Old 02-21-2014, 07:09 PM   #2 (permalink)
Icecobra's Avatar
This was my choice and I am 10,000 miles in and no problems at all thanks...
Lord, make my hand fast and accurate.
Grant me victory over my foes and those who wish to do harm to me and mine.Let not my last thought be 'If I only had my gun."And Lord, if today is truly the day you call me home, let me die in an empty pile of brass. My biggest fear running out of ammo
Icecobra is offline
Old 02-21-2014, 07:12 PM   #3 (permalink)
Awesome! Glad to hear it. I'll be posting some more videos and pics soon. Thanks!
Old 03-14-2014, 02:01 PM   #4 (permalink)
DirtSlinger22's Avatar
Junior Member
I've heard bad things about level kits on the Raptor about them tearing up the shocks. Is that true? I want to level out my Raptor but don't want to hurt the shocks by doing it.
DirtSlinger22 is offline
Old 03-14-2014, 06:39 PM   #5 (permalink)
formuladriver01's Avatar
How will this work with mid pearch mod and with out? Also some before and after pics would be awesome please.
Current family vehicle:
2005 Toyota 4Runner, Sport Edition, 4x4, 4.7 V8...My ride for now.
2008 Lexus GX470...The wifey's ride.
After I return to the states, I will buy my silver Raptor with all the goods!
formuladriver01 is offline
Old 03-18-2014, 05:09 PM   #6 (permalink)
Unless the kit was installed incorrectly, or the vehicle was taking some seriously heavy abuse off-road, I do not see how a leveling product could hurt the shocks. The strut extension is used to level the vehicle while providing a mild lift. As this T6 billet extension is mounted on top of the strut and doesn't require any additional modification, its a relatively simple and easy way to get that extra lifted and leveled look on the Raptor. Bottom line, installing the ReadyLIFT T6 Billet strut extensions is designed to give you a 2" lift in the front while maintaining your factory ride and without harming your shocks. More specific product details at: www.readylift.com
Old 03-18-2014, 06:23 PM   #7 (permalink)
By modifying the perch of the shock, you can get about a 1.5" lift on the Raptor, but you would end up with a stiffer ride overall, because you are compressing the spring and increasing the spring rate. By installing the ReadyLIFT T6 Billet kit you can receive a 2" lift in the front while maintaining factory ride as the extension goes above the strut. Were you looking to do both? If that is the case, this would not be recommended as you would bind up the CV's. You could achieve a better ride, and lift with the leveling kit rather than making the mid-perch alone and you would definitely want to stay away from trying to combine these two modifications. More info at: www.readylift.com
Old 03-19-2014, 05:26 AM   #8 (permalink)
Thanks for the reply. I don't have a raptor yet I was just curious if M/P would be affected. Will look into it more when I get my raptor.
Old 03-19-2014, 08:56 AM   #9 (permalink)
Yukon Joe's Avatar
Don't hurt the shocks. It is the front cv axles you have to worry about.
Icecobra had had success running this setup. Others haven't. Inspecting you front drive line would be a safe way to ensure it is wearing properly and not broken before you would need it.
Yukon Joe
www.RUNRAPTORRUN.com
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline
Tags
billet aluminum, front, leveling kit, lift, suspension
2" leveling kit cubiefan101 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 9 03-19-2014 01:41 PM
RECON FORD SVT RAPTOR ILLUMINATED TAILGATE EMBLEM in *RED* 2010-2014 **NEW** renegadeagle Ford Raptor Lighting Modifications Forum [GEN 1] 17 12-17-2013 05:18 PM
