Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Engine Discussion and Performance Mods-5.4 Liter Triton V8 [GEN 1]
High idle speed when warm
This is a discussion on High idle speed when warm within the Ford Raptor Engine Discussion and Performance Mods-5.4 Liter Triton V8 [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Recently I have an issue with the idle. I have a 2010 Raptor 5.4 with a E Force S/C with ...
Old 06-26-2018, 09:03 PM   #1 (permalink)
djmacc's Avatar
Junior Member
Default High idle speed when warm
Recently I have an issue with the idle. I have a 2010 Raptor 5.4 with a E Force S/C with 150,000 miles.It starts fine goes into fast idle as it should then settles in around 650 rpm. After a half hour of driving the idle creeps up and eventually stays around 950 rpm (in park). This is very consistent it always idles fine for the first 1/2 hour or so then ends up at 950. There is a little surge at the 650 idle but very little. I assumed I had a vacuum leak and so I sprayed all the usual places looking for the leak then bought a smoke machine but still no luck in finding a vac leak. I also replaced the Tbody including the IAC and TPS and no change. I tested the brake booster and replaced the break check valve as well. I am running out of ideas which leads me to question the S/C. Outside of a gasket leak at the base of the S/C is there any way it could be the culprit?
2010 EForce Supercharged 5.4 Oxford White/OEM Projector-LED Halos-Demons
djmacc is offline   Reply With Quote
Old 07-04-2018, 08:59 AM   #2 (permalink)
1BAD454SS's Avatar
bad mass air meter? or leaking hose clamp tubing after meter.
2014 FX4 Tremor 420rwhp ,2010 Raptor 6.2L 2.9 Whipple 650 hp kit .2002 Lightning 3.4 whipple 800 RWHP, 1993 454 SS 502 ci and 2.4 kennebell, 1979 10th annivesary trans am 400 4spd ,2015 POLARIS Scrambler 1000,
1995 BANSHEE ,1985 Yamaha RZ500 4 cylinder 2stroke
1BAD454SS is offline   Reply With Quote
High speed offroading with toolboxes radio_man Off-Roading Your Raptor 7 08-28-2017 09:32 AM
High speed stability donk_316 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 2 06-02-2017 03:32 PM
High fan noise at startup idle goinsvt Ford Raptor Problems and Questions Forum 8 07-28-2013 11:15 AM
Offroading High Speed JP7 Off-Roading Your Raptor 71 05-12-2011 11:01 PM
