- Joined
- Oct 31, 2013
- Posts
- 401
- Reaction score
- 172
Amongst the full line of aFe Engineering products we carry, we also offer the aFe rear differential cover for all 12 bolt 9.75" Ford rear differentials. Free Shipping on all orders over $99 to the Lower 48 .
aFe Power 46-70152 Rear Differential Cover
aFe Differential Cover: aFe Power's new rear differential cover brings performance engineering to the protection of your trucks rear-end. This differential cover has a 5 quart lube capacity (factory cover holds 4 quarts) at the factory line , a magnetic drain plug, a magnetic tipped fill plug for maximum rear-end protection. Built-in internal and external fins transfer heat from the fluid to the outside air for maximum cooling. aFe has also designed a large oil level site glass with calibration plug set to the factory fluid level to eliminate overfilling.
This differential cover is constructed out of durable die-cast A380-T6 aluminum with reinforced ribs and a wrinkle black powder coating with machined fins for maximum strength and styling. This cover uses an O-ring mounted in the machined channel for a leak-free seal.
When it comes to engineering for power, performance, protection and value, aFe Power is the only choice.
