Tracker Series LED Light Bars!
SideTracked
Folsom, CA
These are our Tracker Series light bars. These use 3w CREE LEDs. They have an 8* spot pattern and a 90* flood pattern. Tracker series light bars mount off the end caps. Have a poycarbonate lens, are IP67 rated for water and dust and have a 1 year warranty.
6" - 50" Dual Row Light bars:
6" Dual Row Light Bar (36w) - $80
. 12 3w CREE LEDs
. Raw Lumen:2640
. Operating Voltage: 10-30 DC
. Waterproof rate: IP 67
. Body Color: Black
. Color Temperature: 6000K
. Housing: Diecast aluminum
. Lens material: Poly Carbonate (Lexan)
. Mounting Bracket: Aluminum
. Beam pattern: Spot/Flood/Combo
. Dimensions:7.5 inch
12" Dual Row Light Bar (72w) - $160
. 24 3w CREE LEDs
. Raw Lumen:5280
. Body Color: Black
. Dimensions:13.5 inch
20" Dual Row Light Bar (120w) - $220
. 40 3w CREE LEDs
. Raw Lumen: 8800
. Body Color: Black
. Beam pattern: Combo / Spot / flood
. Dimensions:21.5 inch
30" Dual Row Light Bar (180w) - $320
. 60 3w CREE LEDs
. Raw Lumen: 13200
. Body Color: Black
. Dimensions:31.5 inch
40" Dual Row Light bar (240w) - $410
. 80 3w CREE LEDs
. Raw Lumen: 17600
. Body Color: Black
. Dimensions:41.5 inch
50" Dual Row Light Bar (288w) - $500
. 96 3w CREE LEDs
. Raw Lumen: 21120
. Body Color: Black
. Beam pattern: Combo / Spot (8*)
. Dimensions:50 inch
SideTracked
SideTracked
Folsom, CA
Fully submersible. I have had these under water all day, no leaks.
These do not get hot either, they'll get warm but nothing like an old halogen light. No vibration issues, etc.
SideTracked
SideTracked
Folsom, CA
Couple night shots.
Low beams:
20" spot bar
The next three are from a customer, probably my favorite set of customer pics so far. Low beams, high beams, 20" combo bar.
SideTracked
SideTracked
Folsom, CA
it's been awhile since I've updated this. lots of new products in stock since then...
Single row bars are now available as well in 15"-50" sizes. these use 10W CREE LEDs and are very bright. Same size housing as the dual row bars, but put out a little more light in a more defined pattern and draw a little less power than the dual row bars.
Also have Tracker HD Pods available in both 60 and 90 Watt sizes. 10W LEDs are used in these also. Very bright and heavy duty light. These weigh in at about 6 pounds!
Tracker T6 pods, 18W in the same size housing as the 2x2 pods. Can be used in the fog light kit as well.
I'll get some more new products up soon, still testing those...
NickPic83
Rockland County NY
can I get a price on the new 30" single row with the 10w LED's. its not on the site. also interested in the flush mount lights too. I would like some pricing on that as well
Danactive
I'm Back!
Syracuse, NY
do these lights work with lets say a rigid mounting rack? i have a 30" rigid light mount that i would like to use your light in... it made more sense to buy their bracket and use another 30" light than to build my own...
