Model 54 Rotary Bender - 90 degree 1 shot with auto stop feature
JDSquaredInc
Johnson City, TN
Great for car projects, boats, hand rails, and most fabrication needs!
- Includes Bender, Stand, Pump, Cylinder, and Target Set Feature.
- Bends from .5" OD to 3" OD tubing.
- Max wall thickness is 2" OD x .250 wall and .120 for anything above 2" OD.
- Bends up to 1.5" Solid tubing.
- Supports up to 12.5 Center Line Radius.
- 1 shot 90 degree bend
- 2 shot 180 degree bend
- Quick release toggle lever to allow for easy removal of tubing.
- Set Target Feature (Set the degrees desired and the hydraulic unit will automatically stop the bend at the degree every time.
- Computer readout of degrees to the .1 degree.
List Price: $3,975
---------- Post added at 11:36 AM ---------- Previous post was at 11:14 AM ----------
Model 54 Toggle Lever mechanism
JDSquaredInc
JDSquaredInc
Johnson City, TN
Model 54 with a 3" OD die set. The bender was successful bending 3" OD (9.0 clr) with a .120 wall thickness.
