Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > Filthy Motorsports
Filthy Motorsports
Ford Raptor Long Travel Air Bag Kits!
This is a discussion on Ford Raptor Long Travel Air Bag Kits! within the Filthy Motorsports forums, part of the Ford Raptor Forum Supporting Vendors category!
Originally Posted by Filthy Motorsports Read the post just above yours... Sorry bud didn't see that when I made my ...
Like Tree17Likes
Old 07-12-2013, 09:06 PM   #21 (permalink)
GoMuscles's Avatar
Sorry bud didn't see that when I made my post. Didn't mean to flame homie I was just tossing it out there for discussion.
GoMuscles is offline
Old 07-13-2013, 11:52 AM   #22 (permalink)
GoMuscles's Avatar
Originally Posted by Steele16 View Post
This is a horrendous thread jack. Also, that SDHQ setup would be torn off in no time, the hangers are what looks to be at least 3-4" below the hitch.
Not at all, I talked to Vince yesterday and the traction bars do not extend past the axel and allow something like 14" of travel incase you upgrade your rear shocks and leafs.
I think the thread became crap when we thought it was being pitched as a "long travel system" and or best solution available. Truth is if you have the money there is a better system that allows you the ability use bags and upgrade the rear suspension with out one hindering the other. Not tryn to pump SDHQ but I know when Im looking for solutions I rarely take the less expensive route just bc its bit me in the past. Next weakest link and such...
wiz1500 and any joe like this.
Old 07-15-2013, 01:02 PM   #23 (permalink)
Filthy Motorsports's Avatar
All PMs returned, thanks for the orders!
Filthy Motorsports is offline
Old 07-15-2013, 01:18 PM   #24 (permalink)
bstoner59's Avatar
does it come in shmedium?
Anyone with minimal knowledge of cars could look at one pic of this system and know it's not long travel in the true sense. Stock springs and shocks mean you are not getting more travel than the stock setup. Not that hard to see. Ford calls the Raptor "long travel". SDHQ's kit that allows for 14" would only be considered a "mid travel". Give the vendor a break...he's just trying to kick some boxes out of his warehouse and pay some bills.
bstoner59 is offline
Old 07-15-2013, 01:38 PM   #25 (permalink)
We use the term long travel because this setup does not limit the factory suspension travel and allows the rear axle to droop out unrestricted. A typical air bag setup will restrict your droop travel, this one will not, thus it is longer travel than a typical air bag setup. I didn't think that needed clearing up, but there it s :)
Air bags are designed to be used as overload springs for towing and hauling and I don't really see the point of needing an airbag kit that stays connected to the axle through the entire cycle. You're not going to be off-roading or racing with a trailer.
Old 07-15-2013, 08:42 PM   #26 (permalink)
Droop is unrestricted I don't argue. But let me ask you a question......as a vender that understands the way raptor suspension works...... what good is droop, if the suspension can not cycle upwards?? This is where "this setup does not limit the factory suspension travel" is not a true comment.
any joe is offline
Old 07-16-2013, 11:14 AM   #27 (permalink)
*Sorry, I meant to say does not limit factory droop travel. Up travel is limited by about 1".
Want to go racing for the weekend? The bags can be removed/re-instaleld in about 5 mins.
Problem solved.
Old 07-16-2013, 07:30 PM   #28 (permalink)
Problem solved.
You are hired!!!!! The brackets need to be removed because they hit each other and bend. So if you can do it in 5 min you are hired.
Just saying!!!
any joe is offline
Old 07-19-2013, 01:27 PM   #29 (permalink)
Old 07-31-2013, 01:53 PM   #30 (permalink)
Important Update
After a little bit of help from a customer of ours, we found out where the discrepancy is between our experience with this kit and that of those who have had trouble with it.
Unbeknownst to us, Firestone changed the F150 kit at some point and removed the height adjustable upper air bag bracket that allowed us to install our kit such that it offset the cradle and worked perfectly.
With a few modification, the current kit can be made to work the same way and we will either add the details to the kit and/or possibly make the modifications at our shop and offer it again as a bolt-on kit.
Anyway, I'll leave this up for a bit and then kill this thread and re-post it with the current details.
Cheers.
Tags
air bag, overload, suspension
Outlaw Raptor Long Travel Kit... BE SCARED Outlaw Offroad Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 70 04-18-2014 12:20 AM
SDHQ's long awaited, long travel air bags! SDHQJASON SDHQ Offroad Racing 22 06-06-2012 12:16 PM
Who's Raptor Is This....Long Travel Kit INI Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 2 12-10-2011 05:13 PM
