Strange fluid after few jumps
dark1024
Cupertino, CA
Hi, it's probably nothing but I've noticed a strange fluid (like water but oily) dripping from the skid plate, is this normal? I also noticed that it has like a canal for that purpose, so it made me think is for that purpose, can anyone confirm?, what is supposed to be dripping?
CP RAPTOR
Nova Scotia, Canada
I'd check to see if your oil filter is tight or the seal is seeping, I've seen the seal tear or fold if put on dry and seep under pressure (more than idle).
Deleted member 12951
The only thing I found that leaks per say when doing stuff like that is power steering fluid out the overflow and drips down the side of the LF side. That definite looks like a loose oil filter but I know nothing about this.
dark1024
dark1024
Cupertino, CA
I just called ford and they don't have "space" available (nearest date is August 12) to receive my truck :/ bummer, any other recommendation?
