Changing Order
BigBOSS
Austin, TX
At what point can you not make changes to an order. Once it's pulled and assigned a vin or when the window sticker is available?
For example, my build week is 2/10 and I have my VIN. Too late to change anything?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Deleted member 12951
So what are you doing? On the thread about the order process talks about that, btw.
Sent using Tapatalk
BigBOSS
BigBOSS
Austin, TX
I keep debating on adding the front camera. I'd only add it if I decided I would get the NAVTV too
locktech
New Jersey
I'm pretty sure once the order is pulled you can no longer change the order.
GOTSVT?
Ma
I was told you can't after VIN is issued. Only what I heard.
Raptor911
Ashburn, VA
TOO LATE! Once your order is pulled you can NOT make any changes.
