Thanks. Expensive hobby this one lol
Now I'm planning on removing the hood and bedside graphics to replace them, so I believe that should be the perfect timing to polish the car and apply the paint coating before getting the new ones.
Which polisher would you get, a 15 or 21mm Rupes or Rupes mark ll or nothing that fancy such as..?
looking for an electric pressure washer if you can recommend one?
Definitely machine polish the paint after the old graphics are removed, but the new graphics should be installed BEFORE the
Ceramic Paint Coating is applied.
The Rupes are excellent machines, but most people find them a bit out of budget, especially if they only get used a few times a year.
And with any of the long-throw polishers that use a 5.5"-7" pad, a second smaller machine with a 4" pad is needed to get into tighter or narrow areas, like up the door pillars or the painted mirror caps. While it is possible to polish only with a larger machine, it can be awkward and leave areas uncorrected.
To get both the
Rupes LHR 15 Mark II and the
LHR 75E Mini, you're looking at $700. We don't stock the previous version of the LHR 15, but you can find it on the web for about $100 less than the Mark II. The
Rupes LHR 21ES with its 7" pad is more geared towards production detailing shops, not weekend shine warriors.
To fill the void between those pro-level polishers and an entry-level polisher like the
Porter Cable 7424XP, Adam's offers the
Swirl Killer 15mm LT Polisher and the
Swirl Killer MINI 12mm LT Polisher. These are listed on sale at $230 and $150, but you can use a sale discount code to bring the price even lower. There is also the
Swirl Killer 15mm & 12mm Combo listed at $360, but a sale discount would bring the price down to $306.
For a budget-level electric pressure washer, many members over on AdamsForums.com have had good results with the Ryobi or Greenworks models that run around $100. They are loud, and don't have the pressure of higher end models, but they work better than just using a garden hose, and you get the benefit of using a
Foam Cannon.
On the higher end of electric pressures washers, the AR Blue Clean AR630TSS-HOT is excellent. Pressure and flow similar to a gas, can run warm water, and it has auto shut-off. Only con is the $769 price tag!
Middle ground on an electric pressure washer, I would go for an AR Blue Clean or Karcher in the $200-250 range.
