RSiWORKS is now an ICON Vehicle Dynamics DEALER
R
RSiWORKS
S.C.S. Michigan
Get ultimate control of your ride with ICON's
"STAGE 2 KIT"​
Don't be left in the dust!
Contact me personally for special pricing.
[email protected]
cell:586-709-0455
ask for Roger
R
RSiWORKS
S.C.S. Michigan
BUMP!!!
Protect your investment.
Ford Raptor Rear Hydraulic Bumpstop System
Contact me for special pricing.
R
RSiWORKS
S.C.S. Michigan
ICON's
Power Steering Solution
Ford Raptor Power Steering Reservoir
MSRP: $349.95 excluding tax / plus shipping
Contact me for your FRF pricing.
After hours of testing and offroad abuse on the ICON Vehicle Dynamics Ford F-150 SVT Raptor we felt solution was needed to further improve the overall performance and function of the OE steering system. When pushing this vehicle to its maximum potential it was apparent that the factory power steering system would develop aeration and lead to a foaming of the fluid in the OE reservoir accompanied with a loud fluid whining or "growling" noise. These symptoms would ultimately lead to reduced life and performance of the steering rack. Power Steering Solution has developed a high performance billet aluminum reservoir that not only increases the overall fluid volume, but includes an anti-cavitation valve as well. The combination of cutting edge design and engineering has led to an easy to install bolt on reservoir upgrade that installs within 30 minutes, in the OEM location, with factory hoses and hardware. The CNC machined power steering reservoir also includes a threaded o-ring cap with a 12psi pop off valve to eliminate increased pressure build during extreme use conditions.
Key Features:
• Direct bolt in replacement w/ no additional components required (additional fluid supplied)
• CNC machined from 6061 aircraft grade aluminum
• Threaded o-ring cap w/ 12psi pop off valve
• Built in anti-cavitation valve designed to eliminate fluid ariation / foaming
• Increased power steering reservoir fluid volume with increased flow
• High end AN fittings for factory-like seal to OEM power steering lines
Made in the USA
Tech Info:
• Bolts on easily with basic hand tools
• Includes additional fluid required for installation
:smile:
R
RSiWORKS
S.C.S. Michigan
Upgrade to the next level of EXTREME PERFORMANCE
images
2010 - Current Ford SVT Raptor ZETA 3.0 Rear Piggyback Reservoir Bypass Shocks
Contact me for your suspension needs.
Ask for the FRF Discount!
:rockit:
R
RSiWORKS
S.C.S. Michigan
RSiWORKS November SPECIAL
From now till the end of November
receive a FREE set of
" ICON Shock Wraps Neoprene Coil Over Shock Protection Covers "
when you purchase a set of
"2010 - Current Ford SVT Raptor 3.0 Front Coil Over Shock System w/ Compression Adjust" or any shock kit
Contact me for your ICON FRF savings today.
:peace:
R
RSiWORKS
S.C.S. Michigan
RSiWORKS November SPECIAL 10 Days Left
:peace:
