not without a lot of modifying. the treo needs a lot of airspace, so you would need to remove the air vents and all the storage in the center console. even then you would not have enough airspace. basically it requires the same amount of airspace as a jl13w7 and external dimensions of a box for the 13w7 is about 3 cubic ft. if you are willing to spend a lot of money to get a custom fit box, then im sure we can build something, but for that woofer, the only feasible possibility is to have a box on the floor. and bolted down. the speaker weighs a lot. not to mention the weight of the enclosure. if i were you i would not try to fit it in the truck. the treo subs are more for spl and not sound quality. the spl competitions i used to go to, we had treo subs and we would "blurp" them. sounded like crap with music, but insanely loud. simply put, not recommended in these trucks.
