Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > LEX Motorsports
LEX Motorsports
It's Getting Hot LEX has your back Dual Row Coolers
This is a discussion on It's Getting Hot LEX has your back Dual Row Coolers within the LEX Motorsports forums, part of the Ford Raptor Forum Supporting Vendors category!
Hey guys, We have a pre-summer special for you guys, LEX is offering the CSF Dual-fluid oil cooler, and mounting ...
Like Tree7Likes
Old 06-09-2015, 07:55 PM   #1 (permalink)
lexmotorsports goodguy's Avatar
Default It's Getting Hot LEX has your back Dual Row Coolers
Hey guys, We have a pre-summer special for you guys, LEX is offering the CSF Dual-fluid oil cooler, and mounting bracket for 800$ to your door shipped, in the lower 48.
We have had great success with these coolers in the AZ desert, Keeping trans temps low and steering temps low.
The Coolers come equipped with built in fan shroud and 9 inch SPAL fan
9.7 inches tall (~10 inches)
13.8 inches wide (with brackets) ~14 inches)
5.15 inch thick (with fan) - 5.65 inches wide with bracket overhang
17 rows of cooling - split up into 2 sections of: 5 rows (30%) and 12 rows (70%)
Built in AN-10 male fittings (plug and play)
The coolers have been pressure tested at 120 psi with extruded aluminum end tanks for max durability
This is a must have for summer offroading. Take advantage of this Deal today.
[light mounts can be included on the cooler mount for no extra charge if requested] [30" light, does require modification to the hood latch]
Performance :: Transmission Cooler :: CSF Dual-fluid oil cooler
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Jason Lader
Build Consultant/FORD RAPTOR PARTS
Vehicle wraps
[COLOR="Red"]
http://raptorsvtparts.com/
http://lexoffroad.com/
480-361-0513
[email protected]
lexmotorsports goodguy is offline   Reply With Quote
Old 06-09-2015, 08:51 PM   #2 (permalink)
upscrazy8's Avatar
Wow! How much more fluid will be required? Thx
TRR13-check, HITH13&14-check, Havoc15-check, Red Desert Run15-check, Snoball II&III-check, Snoball IV-pending, Smky Mtn Run14-check, ARDD14-check
upscrazy8 is offline   Reply With Quote
Old 06-10-2015, 06:34 AM   #3 (permalink)
The Car Stereo Company's Avatar
aka nosbusa
thats pretty damn cool that you have integrated a light bar mount into the setup.
its not how fast you can go......its how fast can you get to fast......
The Car Stereo Company is offline   Reply With Quote
Old 06-10-2015, 06:41 AM   #4 (permalink)
RLTW's Avatar
that bumper catches my eye every time i see it
ICON 3.0 - ICON UCA - ICON Leaf Springs - SVC Bypass Rack - Custom King 4.0s - ICON BUMPSTOP/FRAME SUPPORT - RPG TIE RODS - ICON LCA SKIDS - UMP INTAKE - MBRP TURDOWN W/RES - 5STAR TUNE - METHOD 17" 105 BEADLOCKS - 37" BFG BAJA T/A KR - RPG RACELINE FRONT/REAR BUMPER - R1 BRAKE PACKAGE WITH AMSOIL FLUID AND SDHQ SS LINES - 5 x 6.7 VIS X LIGHT CANNONS - BD 60" ONNX ARC RE - BD S2 RE - LINEX BED - CRAVEN STUBBY
RLTW is offline   Reply With Quote
Old 06-10-2015, 01:40 PM   #5 (permalink)
If I remember correctly, 3 quarts of trans and 1.5 quarts of steering.
that's what we are hoping for.
Jason Lader
Vehicle wraps
[COLOR="Red"]
480-361-0513
[email protected]
Old 06-11-2015, 01:32 AM   #6 (permalink)
New Guy's Avatar
Hey Jason, can you please tell me what the difference is between this Dual-Cooler and the Alpha-1 cooler ya'll have?
Also, it seems that I'm out of outfitter switches and don't really have the intention of switching up wiring and switches or adding more any time soon, so was there a way for the Alpha-1 to remain in the constant-On ?
Sorry for the ignorant questions, its just I've gotten some extra held-pay that Uncle Sam decided to gift to me and I'd like to get something for my truck before I go on Deployment. Thanks!
Do you find yourself Lurking these Forums? Is that ever persistent Google search bringing you back Here? Do you ever find your pulse quickening at points as you Read? If so, say no more and Join Today.
Buy Once, Cry Once - Bitches
New Guy is offline   Reply With Quote
Old 06-11-2015, 02:50 PM   #7 (permalink)
New Guy,
The Alpha 1 cooler on our site is a single cooler generally for transmission, The CSF cooler is a dual cooler that we use for transmission and steering, both in 1 unit.
Understood on the upfitter switches, we have run a small toggle on the bottom on the plastic panel under the steering wheel, very low key.
Jason Lader
Vehicle wraps
[COLOR="Red"]
480-361-0513
[email protected]
Old 06-11-2015, 02:56 PM   #8 (permalink)
RDFTS's Avatar
aka Rick
If you have a 40" bar behind the grill under the Ford, will this cooler work?
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR & Raptoberfest 14'/15'/16'/17'/18' | Time Attack 14' | Snoball 15'/18' | AR Run 15' | TRR Baja 16'/18' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 06-11-2015, 06:00 PM   #9 (permalink)
Sorry I don't think so, we were not able to fit a 40" baja designs light under it, we tried, a few ways,
Jason Lader
Vehicle wraps
[COLOR="Red"]
480-361-0513
[email protected]
Old 04-15-2016, 03:17 PM   #10 (permalink)
I'm interested in this set-up as sometimes while towing our travel trailer the trans gets a little warm as well as during long off road in the desert. Seems like cooling the power steering fluid would help, but do I need a reservoir as well? Is over heating fluid the most common cause of pump failure? My power steering system whines after more than an hour off road.
BABaracus is offline   Reply With Quote
Ice hole coolers group buy treypal Garage Sale 68 08-18-2014 08:15 PM
Yeti Coolers treypal Garage Sale 174 07-01-2014 09:49 AM
Transmission coolers iHaveGas Ford SVT Raptor General Discussions [GEN 1] 20 11-07-2013 09:10 AM
Cactus coolers Squatting Dog Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 21 06-14-2012 12:14 AM
