MSDS
WARRANTY
Product Description
AMSOIL Antifreeze & Engine Coolant is formulated to provide benefits far beyond those found in today’s conventional antifreeze and coolant products. This revolutionary formulation provides maximum antifreeze and cooling protection in the most extreme temperatures and operating conditions. And unlike conventional ethylene glycol-based products, which are acutely toxic, AMSOIL Antifreeze & Engine Coolant is formulated with propylene glycol. It is biodegradable and its low toxicity limits the threat to children, pets and wildlife.
Lasts Longer
AMSOIL Antifreeze & Engine Coolant contains a proprietary poly organic acid technology. It eliminates the need for supplemental coolant additives and recharging cooling systems. AMSOIL Antifreeze & Engine Coolant provides extended service life in all gasoline and diesel vehicles. It can be used for seven years or 250,000 miles in passenger cars, light-duty trucks, vans and recreational vehicles. It lasts seven years or 750,000 miles in over-the-road diesel trucks. Also good for motorcycles, ATVs, snowmobiles and closed marine applications. AMSOIL Antifreeze & Engine Coolant lasts longer than conventional products.
Compatible With Other Fluids
AMSOIL Antifreeze & Engine Coolant is dyed neutral yellow and is compatible with all ethylene and propylene antifreeze and coolant formulations on the market, including DEX-COOL®, Sierra® and Zerex®. It is also compatible with fully formulated diesel antifreezes and other organic acid technology (OAT) and hybrid organic acid technology (HOAT) formulations.
Helps Stop Leaks
AMSOIL Antifreeze & Engine Coolant adheres to metal. It self-seals hairline cracks in welds and seams to help prevent leaks, without additional stop-leak products or fibrous materials.
Helps Prevent Metallic Corrosion
Independent tests reveal AMSOIL Antifreeze & Engine Coolant surpassed standards for metallic corrosion. It plates metal to protect even when exposed to acids and salt spray. Standard allowances for loss in aluminum and solder are less than 60 mg. AMSOIL Antifreeze & Engine Coolant lost 0 mg in aluminum and less than 6 mg in solder.
Standards for iron, steel, copper and brass allow a maximum loss of less than 20 mg. AMSOIL Antifreeze & Engine Coolant never exceeded a 3 mg loss in any of those metals in a testing period that was run for 10 weeks, three weeks longer than required tests.
Formulated for heavy-duty and automotive applications
Good for motorcycles, ATVs, snowmobiles and some marine applications
Extended drain intervals
Up to seven years or 750,000 miles in over-the-road diesel trucks
Up to seven years or 250,000 miles in passenger cars, light-duty trucks, vans and recreational vehicles
Biodegradable, low toxicity, non-polluting
Aluminum engine block compatible
Contains no nitrates, nitrites, phosphates, silicates, borates, amines or molybdates
Dispose of used antifreeze according to local, state and federal regulations
APPLICATIONS
AMSOIL Antifreeze & Engine Coolant can be used in any applications requiring the following specifications or tests:
ASTM D 6210, D 3306
Caterpillar EC-1
Chrysler MS-7170, MS-9769
Cummins CES 14603
Detroit Diesel 93K217
Ford WSS-M97B51-A1, WSS-M97B44-D
Freightliner 48-22880
GM DEX-COOL®
John Deere 8650-5
Mack Trucks CN H
TMC RP-330
US Military CID A-A-52624-A
Composition by Weight:
Total glycols, > 92 percent;
Corrosion inhibitors and antifoamants,
= 8 percent; Water, < 1 percent
Boiling Point (sea level):
219° F at 40 percent concentration,
221° F at 50 percent,
225° F at 60 percent;
increase by 40° to 45° F if a 15 psi radiator cap is used
The RETAIL Cost of this coolant is $39.45 per gallon before adding shipping and local sales tax. (AMSOIL charges sales tax on all orders according to the tax rates in the state and local area of delivery) But CLICK HERE or message me for details on how to get it shipped for less than the regular retail cost even after adding shipping and sales tax.
