Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > Krazy House Customs
Krazy House Customs
Rod End Boots- extend rod end life
This is a discussion on Rod End Boots- extend rod end life within the Krazy House Customs forums, part of the Ford Raptor Forum Supporting Vendors category!
Saw these a few times and I finally found a source for them. These really help extend the life of ...
Like Tree10Likes
Old 08-19-2013, 07:00 AM   #1 (permalink)
khcdave's Avatar
Default Rod End Boots- extend rod end life
Saw these a few times and I finally found a source for them. These really help extend the life of your hiem joints (aftermarket steering setups) especially when you use it offroad and during the salty snowy winters we have here. Mud and salt kill them. I wear my rod ends out quick so with these protective boots and a little bearing oil I extend their life big time. These fit 3/4 and 7/8 rod ends. 15.99 for 2 plus shipping
khcdave is offline   Reply With Quote
Old 07-21-2014, 06:13 PM   #2 (permalink)
Ordered mine today!!
LEADING AMERICA FROM THE BACK OF THE LINE
mudblood is offline   Reply With Quote
Old 07-21-2014, 08:58 PM   #3 (permalink)
Huck's Avatar
Best way to install these is steam them first. Otherwise they don't stretch enough to fit over the heim end
Borrow the wife / significant others vegetable steamer.
Icom F5021,RPG Stg 4+ Fox 3.0 coilovers, RPG Tie-rods (modified to camburg hardware), RPG PS reservoir, Camburg 1.25" UCA's , Raptor -Retro fit '13 HIDS, Line-x preminum, Bluewater LED bed lights, Ipad mini navigation. Bubba rope. Rollx, Recon 10.5k winch synth rope, factor 55, SVC Custom acuated tower. Visions 30" xmitter extreme, 35" toyo MT, visionx 6550 spot.
Huck is offline   Reply With Quote
Old 07-21-2014, 09:09 PM   #4 (permalink)
Damn wish I would have known about these sooner. Could have used them on my mustangs suspension that is all hiem joints.
2014 Terrain SCREW -
It's turning into a Mutt..
SilentShooter is offline   Reply With Quote
Old 07-21-2014, 10:06 PM   #5 (permalink)
KaiserM715's Avatar
Kaiser Söze
Are these the Seals-it boots? They are indeed a challenge to get on.
'10 Raptor - My build
'08 G8 GT
- sold
'04 MazdaSpeed Miata
'67 Jeep Kaiser M715 - sold
Join the Blue Ribbon Coalition . . . it's YOUR Public Land!
KaiserM715 is offline   Reply With Quote
Old 07-22-2014, 06:27 AM   #6 (permalink)
Yukon Joe's Avatar
Turn them inside out. Then roll it on like a... condom. Lol...
It worked really well.
Dave what kind of grease did you use? The rod ends have a Teflon lining so you need something that won't harm it.
Yukon Joe
www.RUNRAPTORRUN.com
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is online now   Reply With Quote
Old 07-22-2014, 07:35 AM   #7 (permalink)
khcdave's Avatar
I use triflow dry spray on all my rod ends including uniballs. its meant for use on this stuff- doesnt damage teflon inserts. You can get it from REI or online. Spray a little in the boot and it slides right over the rod end.
---------- Post added at 07:35 AM ---------- Previous post was at 07:33 AM ----------
steaming isnt a bad idea either or warm water. Once you spray inside they slide on pretty easy- just need to stretch a little
Old 07-22-2014, 07:56 AM   #8 (permalink)
Yukon Joe's Avatar
Thanks Dave. I used a bit of electrical grease, but will check out what your recommending.
Next time try the inside out method. It literally rolled right over it. I tried heating it and a little lube. But still was fighting it.
Inside out and roll it on backwards. Easy peasy!
Yukon Joe
blockdoc likes this.
I love Raptorwifey
Old 07-22-2014, 08:56 AM   #9 (permalink)
Oh boy I look forward to this challenge. Will try the triflow spray and perhaps also getting them soft with some hot water. Been so long since I used a condom I don't know if I can remember!!
Old 07-22-2014, 10:44 AM   #10 (permalink)
khcdave's Avatar
Use the triflow with teflon for maintenance lubing also- really helps the rod ends last longer
Cv boots pat'sRAPTOR Ford Raptor Maintenance Forum 14 01-28-2013 09:46 PM
Changing cv boots Netix Ford Raptor Problems and Questions Forum 44 01-24-2013 08:33 PM
NPS to Extend Draft SEIS Comment Period and Existing "One Year Rule" KaiserM715 Recreational Land Use Issues 1 09-10-2012 01:46 PM
NPS to Extend Draft SEIS Comment Period and Existing "One Year Rule" KaiserM715 Recreational Land Use Issues 1 09-06-2012 04:10 PM
Inner CV Boots Torn panda Ford Raptor Problems and Questions Forum 10 04-16-2012 11:26 AM
