FOX Raptor Adjusters Ad
Bad_Rooster
Spanish Springs Nevada
2014 MSRP
FOX Factory Series 3.0 Coil-Over Internal Bypass
- Ford Raptor Front set $2699.95 883-02-046
FOX Factory Series 3.0 Coil-Over Internal Bypass DSC
- Ford Raptor Front set $2999.95 883-06-046
FOX Factory Series 3.0 Bypass
- Ford Raptor Rear set $2199.95 883-02-047
FOX Factory Series 3.0 Bypass QAB
- Ford Raptor Rear set $2499.95 883-09-047
FOX 2.5 DSC Adjuster with Aluminum Reservoir Upgrade
- 10" Reservoir kit $299.95 each 810-03-000 (need 2 for raptor front coil-over set)
FOX Quick Adjust Bypass (QAB) Upgrade Kit
- 3/4" tube Compression Blue $79.95 each 815-03-010 (need 4 for raptor rear bypass set)
- 3/4" tube Rebound Red $79.95 each 815-03-011 (need 2 for raptor rear bypass set)
What other than looks does the 2.5 DSC Adjuster kit do for it, make the valving adjustable?
MatMan
AridZona
You can tune the high speed and low speed compression, I believe. Which might actually be useful if you like to tinker with settings.
FOX
FOX
El Cajon, CA
Ok so how to add it? Can the guy at Fibercraft here in Reno do it? Or can I do it my self? Or a must send in thing. If a send in thing how long and how much?
Rebuilding a FOX Internal Bypass shock is a lot more tricky then a standard reservoir shock. Bleeding all of the air out of the internal ports is key.
We recommend that you send them in to FOX for the upgrade.
Contact our service department [email protected] or learn more at ridefox.com/service
