FOX Raptor Adjusters Ad
FOX
El Cajon, CA
tbone
the bay norcal
how much more are this from the others? or are these the new ones being produced to replace those?
pat'sRAPTOR
Everywhere
If I remember correctly these are an option to upgrade to.. You can still get them without the quick adjustment knobs of you want but I'm not sure on the price different I wanna say it's like $150-$200 more a shock for these but I'm not sure fox will have to chime in and correct me haha I'm pretty sure I'm wrong
FOX
FOX
El Cajon, CA
2014 MSRP
FOX Factory Series 3.0 Coil-Over Internal Bypass
- Ford Raptor Front set $2699.95 883-02-046
FOX Factory Series 3.0 Coil-Over Internal Bypass DSC
- Ford Raptor Front set $2999.95 883-06-046
FOX Factory Series 3.0 Bypass
- Ford Raptor Rear set $2199.95 883-02-047
FOX Factory Series 3.0 Bypass QAB
- Ford Raptor Rear set $2499.95 883-09-047
FOX 2.5 DSC Adjuster with Aluminum Reservoir Upgrade
- 10" Reservoir kit $299.95 each 810-03-000 (need 2 for raptor front coil-over set)
FOX Quick Adjust Bypass (QAB) Upgrade Kit
- 3/4" tube Compression Blue $79.95 each 815-03-010 (need 4 for raptor rear bypass set)
- 3/4" tube Rebound Red $79.95 each 815-03-011 (need 2 for raptor rear bypass set)
