Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > FOX Racing Shox
FOX Racing Shox
FOX Quick Adjust Bypass (QAB) Technology Now Available
This is a discussion on FOX Quick Adjust Bypass (QAB) Technology Now Available within the FOX Racing Shox forums, part of the Ford Raptor Forum Supporting Vendors category!
Like Tree7Likes
  • 2 Post By FOX
  • 4 Post By FOX
  • 1 Post By FOX
Old 09-06-2013, 02:15 PM   #1 (permalink)
FOX's Avatar
FOX
Default FOX Quick Adjust Bypass (QAB) Technology Now Available
Quick Adjusting Bypass technology is available as an option for all new 2.5, 3.0, and 3.5 FOX External Bypass shocks or as an upgrade.
The FOX Quick Adjusting Bypass (QAB) technology allows you to manually adjust bypass tubes, quickly and easily, making fumbling with tools and visually counting turns obsolete.
The CNC Machined 6061-T6 aluminum adjustment knobs—anodized blue for compression or red for rebound--are knurled for increased grip, with laser-etched arrows indicating adjustment direction. The adjuster has the same flow and range of adjustment as our regular bypass units. The new design has a definitive click at every quarter revolution of the knob, making adjustments simple and quick—tracking shock changes is now easier than ever. The knobs also feature an O-ring seal to keep moisture and contaminants out, insuring a reliable adjustment turn after turn.
The Quick Adjusting Bypass technology is available as an option for all new 2.5, 3.0, and 3.5 FOX External Bypass shocks or as an upgrade for your existing shocks. The QAB is also standard on the Ford SVT Raptor Rear FOX 3.0 Factory Series Bypass QAB Reservoir upgrade kits. Visit a local FOX Truck or Offroad retailer to purchase. Existing bypass shocks can be upgraded at the FOX Truck and Offroad service center in El Cajon, CA.
Ford SVT Raptor (Rear) 883-09-047 $2500.00 set retail
For complete product details visit: http://ridefox.com/raptorqab
FOX QAB Upgrade Kit
QAB Blue Compression Kit 815-03-010 $80.00 each retail
QAB Red Rebound Kit 815-03-011 $80.00 each retail
For complete product details visit: http://www.ridefox.com/upgrades
MTUH3 and Blind1 like this.
FOX is offline   Reply With Quote
Old 09-06-2013, 02:18 PM   #2 (permalink)
Kanakry's Avatar
Very cool.
The added convenience of not needing tools is a plus
www.RunRaptorRun.com
Kanakry is offline   Reply With Quote
Old 09-06-2013, 02:21 PM   #3 (permalink)
FOX's Avatar
FOX
---------- Post added at 01:21 PM ---------- Previous post was at 01:20 PM ----------
Old 09-06-2013, 02:22 PM   #4 (permalink)
MTUH3's Avatar
Great idea!
Wanna send some my way for cold winter testing this year. wink wink.
I gotta get in touch with you guys on shocks for my other truck soon anyway.
Do you need to do a full shock rebuild to put these one, or can the be installed on the fly?
Carl - Plymouth, MI
2011 Super Crew - MRT Exhaust, Front Icon 3.0 Coilover, Rear Fox 3.0 shocks 2.0 bumps, Hellwig rear sway bar, SVC Upper Control Arms
https://www.facebook.com/RogueWaveIndustries
MTUH3 is offline   Reply With Quote
Old 09-06-2013, 02:23 PM   #5 (permalink)
Macman's Avatar
Awesome!
2012 SVT Ford Raptor Screw - Blue Flame Metallic
2013+ FX4 HIDs|RPG Stage II|Undercover Flex|40" LED Bar|Method NVs|Mid Perch|
1969/77 Ford Bronco
2002 Honda s2000
Macman is offline   Reply With Quote
Old 09-06-2013, 02:29 PM   #6 (permalink)
FOX's Avatar
FOX
Originally Posted by MTUH3 View Post
Great idea!
To install the QAB requires removing of the existing bypass check valve hardware. To remove this hardware the oil will need to be drained and then bled after refilling.
MTUH3 likes this.
Old 09-06-2013, 03:27 PM   #7 (permalink)
MTUH3's Avatar
Code for Send my 3.0's to Fox or RPG and have them fix me up..... but this would be a good reason to practice my rebuild skillz
Carl - Plymouth, MI
Tags
fox, qab, raptor, rear, shock
Fox QAB Knobs (Quick adjusting bypass) ISFast Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 4 10-29-2013 02:39 PM
Ford is using autonomous technology to test dfelicia Ford SVT Raptor General Discussions [GEN 1] 0 06-17-2013 11:44 AM
Do I need to adjust headlights after mid-perch?? Big Blue Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 17 10-06-2012 08:45 PM
Ford Announces New 8-Speed Transmission, Split Cooling System Technology SVTOffroad News Bot Ford Articles, News and Media Reviews 0 06-02-2011 12:40 PM
