Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > Custom Truck Shop
Custom Truck Shop
New wireless controller from Trigger
This is a discussion on New wireless controller from Trigger within the Custom Truck Shop forums, part of the Ford Raptor Forum Supporting Vendors category!
Old 04-18-2017, 05:36 PM   #1 (permalink)
customtruckshop's Avatar
Default New wireless controller from Trigger
TRIGGER Wireless Accessory Controller
The Trigger Wireless Accessory Controller substantially saves installation time of your electronic accessories! Eliminate the need to run wires under the dash or through the firewall of a vehicle when wiring accessories. It also adds functionality such as; an RF remote control for activating installed accessories from outside the vehicle and dimming/flashing functions for installed lighting. In addition, fused circuits with LED indicators notify you of blown fuses.
The included battery-powered RF remote utilizes a universal mounting system that will accommodate round surfaces as well as flat surfaces. Its buttons are backlit and it is programmable for security or use with additional remote’s. Several Trigger control boxes and remote’s can be used together to control up to 24 accessories. When mounted to a UTV roll bar, the buttons on the remote are more easily accessible than dash switches. No straining against seat belts to reach the dash, just a quick reach up to tap the remote.
The Bluetooth App will control on/off and dimming functions as well as flashing when used with LED or conventional lighting. It is simple to set up and allows for user customization. Use the app to “Trigger” lights from outside the vehicle whenever you might need to activate an accessory on demand.
A few notable features:
Accepts 12-24 Volt input
Two 10 amp fused circuits w/12-24 Volt output
Two 30 amp fused circuits w/12-24 Volt output
Includes 4 wire harnesses with waterproof connectors
Wireless back-lit RF remote switch module
Control from your mobile device with our free App!
Store €“ Item Profile - LGE-CTS Motorsports
customtruckshop is offline   Reply With Quote
Tags
controller, lighting, lights, trigger, wireless
Trailer Brake Controller Programming in So Cal goathearder Southwest 0 08-08-2016 07:09 PM
I can't connnect my Nav to my wireless internet. EdgeR6 Ford Raptor Audio/Video/Electronics Forum [GEN 1] 10 03-13-2013 09:03 PM
Help with install of OEM Electric Brake Controller DubbsFaris Ford Raptor Problems and Questions Forum 2 08-01-2011 01:22 AM
