Gen 1 Raptor 3.0 Rear Remote Reservoir Bypass Shocks Take Offs! Need Gone!!
customtruckshop
LGE-CTS Motorsports
San Dimas, CA
I have a pair of Rear Icon 3.0 Triple Bypass w Resi off of the rear of a Gen 1 Raptor (2010-2014)
Shocks have less than 500 street miles on them!!!
Customer went with a different setup
Part number: 95201
Asking $3200 for the pair OR BEST OFFER
Located in San Dimas CA
Shipping Available
(909)599-2228
Ask for John
Key Features of the Raptor RXT Rear 3.0 Bypass Shock:
• 3.0 RXT 3 tube bypass rear shock with 3.0 remote reservoir
• Unique side-mounted upper eyelet allows for increased up-travel while utilizing factory mounting location
• Recirculating Dual Hose Reservoir (Patent Pending) keeps shock temperatures low by pumping heat to the reservoir for increased dissipation
• Anti-Wobble Link (Patent Pending) keeps bypass tubes clear of leaf spring and tire
• Easy-to-Adjust detented adjustment knobs offer quick adjustability without the use of tools
• High resolution bypass valves designed for noticeable fine tune adjustments in rebound and compression
• High flow CNC machined welded bypass blocks designed to increase fluid flow for enhanced performance & high definition tuning
• Replaceable bypass tubes that can easily be replaced if damaged
• Direct bolt in to OEM location with bypass adjustment knobs easily accessible for tuning adjustment
• Special engineered damped valve seats for quiet and precise operation without the standard bypass loud “clicking” noise you will find with other brands
• Multi stage cad plated finish with polished and anodized top cap / rod ends
• Protective shin guards standard with every kit
