Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Recalls | TSB's | SSM's
TSB 13-6-8 Transmission
This is a discussion on TSB 13-6-8 Transmission within the Ford Raptor Recalls | TSB's | SSM's forums, part of the Ford Raptor Forums - General Information category!
I have just over 75K miles on my 2011 and no problems with the transmission whatsoever....
Like Tree5Likes
Old 10-24-2017, 06:01 PM   #41 (permalink)
Ruger's Avatar
"Free men do not ask permission to bear arms." - Thomas Jefferson
"I like my coffee black, and my tea in the harbor." - Jay Posey, author
Ruger is offline   Reply With Quote
Old 10-24-2017, 10:36 PM   #42 (permalink)
Bulletnjm's Avatar
Does anyone have the other thread with the recall in it that stated what years where affected? I believe i looked into it already but im seeing this thread again, so id like to look again
Bulletnjm is offline   Reply With Quote
Old 01-22-2018, 07:01 PM   #43 (permalink)
the yeti's Avatar
I recently had the same issue gave them a copy of the TSB when we brought the truck in around 9 days ago. (They at least gave us a loaner ) I have 85000 miles on my 2013 SCREW. They call and tell me I have a leak in my trans pan and need to replace the gasket and fluid. They are also quoting around $850 to do this. Does this sound right? I haven't got to talk to the service manager as the person I was talking to didn't know exactly. I have seen no fluid leaks in my driveway or garage either.
Please advise
2013 screw blue ordered 8/10/12. Picked up 3/13/13 Delivered on midperch. ADD stealth winch custom punisher cutouts, outlaw raptor hood mounts with HIDX HIDS, M&R 30" upper grill led, 40" M&R led bar, 20" Rigid E series in bumper, Recon 10500 winch, prolink plus, bedrug, roll-n-lock..hopefullys someday stage 4 suspension or Icons
the yeti is offline   Reply With Quote
Old 02-15-2018, 04:37 PM   #44 (permalink)
Junior Member
Howdy all,
I seem to have had a similar experience as @Deinonychus. I Was at the light making a left and as it turned green I pushed the gas and it goes into 1st gear but doesn't shift into 2nd, it just revved and I panic and stop immediately at the side of the curb and turned off the engine afraid that it might have a mind of it's own.
But two weeks before that happened I had the transmission fluid flush and put amsoil in it. As I left the ford dealer i immediately felt a hard shift from 1st to 2nd like I was being rear ended. I thought nothing of it as i read it was a common problem and thought that the additive they put in to flush the gunk out of the tranny before they put the new fluid was causing those hard shifts and after 100-400 miles the tranny will relearn itself and shift smoother. But the hard shift never went away.
So i brought it to the dealer the next day after that 1st gear incident and tell them that ever since they flush the fluid it's been shifting really hard from 1st to 2nd and that it rev out of 1st gear without going into 2nd gear. So the advisor says he needs all day on it and I leave it. I'm out of warranty on my 2013 with 72k miles. So I'm thinking it's the "molded lead frame" issue and is gonna cost 1-2k to fix.
He calls me in the afternoon and says the tranny fluid was low and the tranny tech says that's what caused it. I guess the last tech that did it didn't fill it to a proper level. So they completely redo the flush and put new fluid back in at the correct level and said the shop foreman test drove it and said all is fine and shifts smooth as glass. It did shift so much better as they probably reset the adaptive tranny computer as well as putting the correct fluid level.
Yes it shifts fine and much smoother now. But somehow I'm afraid the real issue might rear it's ugly head down the line as it did with some of those that were affected by the "Molded lead Frame" issue.
So I just wanted to put it out there incase it might help anyone, as checking the tranny fluid level is the cheapest to eliminate first.
I'm no expert and I just wanted your guys take on it? Maybe it is low tranny fluid maybe not?
Thanks
JumpinJax is offline   Reply With Quote
Old 02-15-2018, 04:56 PM   #45 (permalink)
AndysLog's Avatar
https://www.youtube.com/watch?v=vAAB2rfdQiQ
do we have 6r80s?
the lead frame can be had for sub 200-300$ range. another 100? fluids gaskets whatever?
decent little weekend project, no reason it should cost 2k though.
AndysLog is offline   Reply With Quote
Old 02-16-2018, 10:44 AM   #46 (permalink)
KaiserM715's Avatar
Kaiser Söze
Originally Posted by AndysLog View Post
do we have 6r80s?
Yes.
AndysLog likes this.
'10 Raptor - My build
'08 G8 GT
- sold
'04 MazdaSpeed Miata
'67 Jeep Kaiser M715 - sold
Join the Blue Ribbon Coalition . . . it's YOUR Public Land!
KaiserM715 is offline   Reply With Quote
Old 02-16-2018, 11:11 AM   #47 (permalink)
BenBB's Avatar
do we have 6r80s?
Agreed, doesn't look like too bad of a job, I'd include bulkhead connector seals at the same time for a couple bucks. Crazy it's got both of those sensors molded into it, luckily for us it's not like the older ones that had the PCM built into it as well.
"All in all it's a good life, I got what I want, I can't complain"-5FDP
BenBB is online now   Reply With Quote
Old 03-01-2018, 10:49 PM   #48 (permalink)
J DAMAGE's Avatar
Brought my truck to the deal for the trans recall, mind you my truck had not acted up, just figured I'd cover my *** for any future problems.
https://ford.oemdtc.com/2679/16n02-m...ford-lincoln/3
There first try was the reprogramming, didn't work, truck acted up when it choose to, back to dealer a day later , and the pull the codes: P0720, P0722, They cleared the codes, tried shooting the program again, but orded my Molded Lead Frame, 1 1/2 weeks later parts installed, so far so good, they also installed my B&M Trans pan for me, saving me wasting fluids, total cost=000.00. Just have to install my PA dipstick when weather breaks.
J DAMAGE is online now   Reply With Quote
TSB 11-3-25 - Transmission bulkhead connector sleeve leaking transmission fluid pirate air Ford Raptor Recalls | TSB's | SSM's 8 04-17-2016 02:54 PM
Transmission help please! RaptorDDS Ford Raptor Maintenance Forum 9 06-26-2012 10:28 PM
Transmission temp Squatting Dog Ford Raptor Problems and Questions Forum 6 03-29-2012 09:36 AM
Transmission... Bluoval1118 Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 25 01-15-2012 06:07 PM
transmission trucker 2011 Ford SVT Raptor Forum (Reply Only) 2 02-05-2011 01:35 PM
