TSB 13-6-8 Transmission
FordService
...Took it back to ford but they could not duplicate the symptoms after 2 days. Got it back and after about an hour of driving symptoms are back. Taking it back tomorrow. UHHHH
Welcome to the forum, cajun007! Let's see what I can do to help turn this situation around. How many miles are on your Raptor?
Crystal
cajun007
Crystal
Hi Crystal,
It has 26,500 mi and is about 2 months out of the 3yr window. It is at the shop today. I am in a rental/loaner and waiting for them to contact me to let me know if they can pinpoint the problem. They had trouble getting it to throw the codes and duplicate symptoms last time. They were helpful at the service dept. It just remains to be seen if it will fall under power train warranty or not.
I will post results as I know.
FordService
Hi Crystal,
Thanks for offering to keep us updated, cajun007! If you'd like, I'd be happy to escalate this to your regional customer service manager. To get the ball rolling, PM me your full name, best daytime phone number, VIN, current mileage, and servicing dealership.
Crystal
LongStick18
My Raptor with just less than 21,000 miles had a transmission problem that ultimately left me with 3 gears: 3rd, 4th, and 5th. I took it to the dealership where the problem was solved. Below is an account:
Transmission tech wrote:
"Verified check engine light was on. Scanned for codes found code PO722 OSS sensor. Found trans fluid leak inside trans rear bulkhead connector. Performed TSB 13-6-8. R&R molded lead frame connector on megatronics unit. Topped off trans fluid. Cleared codes. Road tested good."
This is a TSB:
TSB 13-6-8 (publication date June 7, 2013)
Issue: Some 2011-2014 Mustang, 2011-2013 F-150, 2012-2013 Expedition and Navigator vehicles equipped with a 6R80 transmission and built on or before 4/8/2013 may exhibit a transmission engagement in 5th gear when starting. The wrench indicator and/or the seat belt minder may be illuminated, the speedometer reads zero and the odometer displays dashes while driving. Symptoms may clear after an ignition key cycle. Diagnostics trouble codes (DTCs) PO720 and PO722 may or may not be stored in the powertrain control module.
Same issue here! has happened three times!
LongStick18
Hi LongStick18,
Have you been to the dealership to have your Raptor diagnosed? If not, I recommend that as a next step. What's your truck's model year/mileage?
Crystal
Service completed today. All covered under warranty. Shifts like a dream now.....
SVTRay
Basically whats going on with my truck.
It want shift through all the gears.
Back story:
I placed the truck in the show 2-3 weeks ago when the wrench light started coming on and I experienced transmission issues. Ford replaced the Mechatronics Unit and i got the truck back 4-5 days later. Today I tried driving the truck and I experienced the same wrench light and slippage. I drove another 10 blocks, turned off the truck, turned it back on and got a check engine light as well as the wrench light. Now the truck doesn't shift through all it's gears...probably only the first 2-3.
2010
91,***
