Note, TSB don't apply to all Raptors/F150's of indicated year. The vin must be run to verify application/build date.
TSB 11-12-2
12/07/11
6R80 TRANSMISSION - EXCESSIVE GEAR SELECTOR
EFFORT - COLD CLIMATE CONDITIONS - BUILT ON
OR BEFORE 11/16/2011
FORD:
2009-2012 Expedition, F-150
LINCOLN:
2009-2012 Navigator
This article supersedes TSB 11-3-8 to add a production fix date, update the vehicle model lines and model years.
ISSUE
Some 2009-2012 F-150, Expedition and Navigator vehicles built on or before 11/16/2011 may exhibit excessive effort with the gear selector lever in cold climate conditions. This may be caused by snow building up around the shift cable and lever. A new snow shield kit has been released to alleviate this condition.
ACTION
Follow the Service Procedure to correct the concern.
SERVICE PROCEDURE
Install a snow shield. Refer to the kit instructions for proper installation.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty/ESP coverage limits/policies are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
111202A 2009-2012 Expedition, 0.4 Hr.
Navigator, F-150: Install
Snow Shield (Do Not Use
With Any Other Labor
Operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
7E395 69
---------- Post added at 01:03 PM ---------- Previous post was at 12:25 PM ----------
TSB 11-12-2
12/07/11
FORD:
LINCOLN:
2009-2012 Navigator
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
Operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
7E395 69
TSB 11-12-2
12/07/11
FORD:
LINCOLN:
2009-2012 Navigator
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
Operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
7E395 69
TSB 11-12-2
12/07/11
FORD:
LINCOLN:
2009-2012 Navigator
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
Operations)
DEALER CODING
CONDITION
BASIC PART NO. CODE
7E395 69
