Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Recalls | TSB's | SSM's
TSB 11-1-5 Canister Purge Valve
This is a discussion on TSB 11-1-5 Canister Purge Valve within the Ford Raptor Recalls | TSB's | SSM's forums, part of the Ford Raptor Forums - General Information category!
I have a 2013, no ticking but it takes 3- 5 seconds to start every time I fill up. Also ...
Like Tree9Likes
Old 10-27-2015, 05:30 PM   #71 (permalink)
intow's Avatar
I have a 2013, no ticking but it takes 3- 5 seconds to start every time I fill up. Also get a check engine light soon after a fill up (usually but not every time). Can't remember the code but it translates to "very small vacuum or emission leak). Guess I'll try changing this out when I get back home and see if it fixes it.
Using Tapatalk
intow is offline   Reply With Quote
Old 07-15-2017, 08:33 PM   #72 (permalink)
RaptorVette's Avatar
Originally Posted by Humvee21 View Post
Just snapped these at work. I believe it's 2x 8mm bolts you remove and disconnect the plug. Pop the new one back in the hole, bolt up, and plug in the wire.. good to go.
Thanks for the post! I just had my truck with 75k miles get a P0445 code and just replace the purge canister and the codes gone!
2013 Raptor - Tuxedo Black SCrew
Mods: SVC tune, ADD Stealth front bumper and ADD Dimple R rear bumper. RPG Fox 3.0's and Deaver +3 springs. SVC Bump Stop kit.
RaptorVette is offline   Reply With Quote
Old 12-07-2017, 05:31 PM   #73 (permalink)
so what is the difference in the below part #s?
9U5Z-9C915-BE
CX2409
CX2383
other than the price they seem to be the same parts unless one is the more up to date version?
2013 Blue Flame Metallic SCREW | Blue accent package | Bronze Method Roost | Roll-N-Lock Retractable Tonneau Cover | KC cube fog lights | OEM spray in bed-liner | more mods down the road?
Raptors4ever is offline   Reply With Quote
Old 12-07-2017, 06:05 PM   #74 (permalink)
9U5Z-9C915-BE
CX2409
CX2383
In for that answer too since I think I am coming up on this issue.
dhanni848 is offline   Reply With Quote
Old 01-03-2018, 08:01 PM   #75 (permalink)
anyone have any idea?
Old 01-05-2018, 07:00 PM   #76 (permalink)
I put a dorman 9U5Z9C915BE in my truck around May 2016. Haven’t had and issues with it if that helps. Bought it on Amazon. And Amazon says the CX2409 doesn’t fit our trucks.
engine45 is offline   Reply With Quote
