TSB 10-25-7 6.2L Engine Tick Noise with Engine Misfire Codes
The Macf
Vegas
@The Macf I checked to see if my plug wires were loose, but I'll go back through and do a closer inspection to check for wear. What did you end up doing to resolve the issue? Replace the one or more plug wires. I guess I just wish I at least knew which cylinder or cylinders were misfiring.
I quit doing full throttle runs to 110 mph on the autobahn.
