TSB 10-21-5
11/08/10
ACCELERATED REAR INNER BRAKE PAD WEAR -
EXTREME MUDDY CONDITIONS ONLY
FORD:
2010 F-150
ISSUE
Some 2010 F-150 vehicles consistently operated in extreme muddy environments may exhibit accelerated rear inner brake pad wear.
ACTION
Follow the Service Procedure to correct the condition.
SERVICE PROCEDURE
1. Wash away mud and foreign material as required.
2. Inspect brake related hardware for proper positioning and function then service as required. Refer to Workshop Manual (WSM), Section 206-04.
3. Install Brake Lining Kit. Refer to WSM, Section 206-04.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
102105A 2010 F-150: Remove Mud 0.8 Hr.
And Foreign Material,
Inspect, And Replace Rear
Brake Linings.
DEALER CODING
CONDITION
BASIC PART NO. CODE
2200 42
11/08/10
FORD:
2010 F-150
ISSUE
ACTION
SERVICE PROCEDURE
Parts Block
Brake Linings.
DEALER CODING
CONDITION
BASIC PART NO. CODE
2200 42
