Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forum Supporting Vendors > Baja Designs
Baja Designs
Lighting Info. - Baja Designs
This is a discussion on Lighting Info. - Baja Designs within the Baja Designs forums, part of the Ford Raptor Forum Supporting Vendors category!
Like Tree6Likes
  • 5 Post By Baja Designs
  • 1 Post By Baja Designs
Old 04-12-2012, 07:05 PM   #1 (permalink)
Baja Designs's Avatar
Default Lighting Info. - Baja Designs
Hey Everyone,
We are new to the forum and wanted to share some information regarding light sources and beam patterns that might be useful when discussing lighting options or comparing products. If you have any questions just let us know.
Zach BD
Candlepower and Lumens
Don’t be misled by lights that are rated by brightness (candlepower).
Candlepower - ratings only measure light from a single point within a beam of light. A tightly focused beam of light may rate a high candlepower but if that light only falls on a very small area, the light will be less than useful. An extreme example of this would be a laser pointer. While the candlepower would be great, the light would be near useless for illumination.
Lumens - are a measure of potential light output. All 35watt, 4200K HID light bulbs produce essentially the same amount of Lumens. A light’s candlepower or lumens measurement is worthless if the illumination is not where you need it.
Light Distribution - Terms
The most effective off-road light will provide smooth light distribution without Sharp Cut-Offs or Hot Spots.
A “Sharp Cut-Off” is where the light drops off dramatically, creating a horizontal or vertical line into darkness. With the pitch and roll of the vehicle, the sharp cut-off affects your ability to see where you need to see.
A “Hot Spot” is an intense concentration of light in a small area. Hot spots can be very distracting while driving off road; your eyes tend to focus on just that bright spot of light bouncing in front of you.
Light Color
The color of emitted light, or "Color Temperature" is rated in Degrees Kelvin. The most usable light for the human eye is sunlight, which is rated at 4000K-5500K. Don't be fooled by lights offering higher temperatures than this - they tend toward the blue spectrum, which is only good for a "cool looking" light. 6100K and higher bulbs produce fewer lumens than the 4200K and 5000K and are less usable to the human eye.
Light Sources
Halogen Lights - like conventional incandescent lights, use bulbs with a filament. The major difference is that Halogen bulbs are filled with a pressurized gas to prolong the life of the filament and allow it to burn at a higher and brighter temperature. The have a color temperature of around 3200K, which makes them appear more yellow in color than sunlight or HID light.
HID (High Intensity Discharge) - lighting is a quantum leap forward in off-road illumination. HID lamps produce a daylight quality light (4200K-5000K) and brightness (3200 lumens). A single HID bulb produces the equivalent of 250 watts of Halogen lighting power, while consuming only roughly 45 total watts of electricity and generating far less heat. Instead of a filament, HID bulbs fire a charge between two electrodes encased in a Xenon gas filled bulb. Since the bulb has no filament, vibration does not affect its operating life of approx. 2000 hours. The benefit of internally mounting the ballast is easy installation and serves to protect the HID components from the elements.
LED (Light Emitting Diode) - lighting has been around for years but is new to the forward lighting off-road scene. Recent advances in technology have made it possible to produce high-output LEDs capable of reaching the performance and pricing of HID lighting. The lights have an extensive life (approx. 100,000 hours) and are very resistant to vibration. The benefits of LED lighting include smooth, even light patterns and the possibility of making the light assemblies in many varying sizes and shapes.
Beam Patterns
Pencil or Spot Beams - provide a longer and narrower beam that focuses the pattern further down the trail. These lights are designed to be used in conjunction with other wider beam patterns. Baja Designs pencil beams come with a 10 degree wide pattern than can be widened by 4 degrees if desired.
Driving Beams - offer better peripheral vision than the Spot while maintaining good distance projection. They can be used alone or with other beam patterns to create an excellent light system. Baja Designs Driving beam have a 20 degree pattern.
Wide-Driving Beams - are slightly wider than a Driving beam and are good for trail riding or filling in spots closer to the vehicle. They can be used alone or with other beam patterns to create and excellent light system. Baja Designs Wide-Driving beams have a 28 degree pattern.
Wide-Cornering or Fog Beams - are the widest and most evenly distributed light pattern of the bunch. These beams are used for lighting the ground close to the sides of the vehicle and are great for turns or twists on the trail. In addition, this beam is great in dusty or foggy conditions. Due to its low and wide angle of dispersion, this beam should always be used in conjunction with other beams to provide the best possible lighting effect. Baja Designs Wide-Cornering beams have a 42 degree pattern.
Baja Designs is offline   Reply With Quote
Old 04-12-2012, 07:24 PM   #2 (permalink)
Blind1's Avatar
Nice information. Need to put your URL in your signature block. I know I know it's on righthand side of the page. Welcome aboard!
LineX Premium & Rear Wheel Wells|55" UWS Wedge Tool w/ HiLift Jack Mounted| Stubby Antenna| K&N Filter| Husky Underseat Cargo Liner| 20" M&R LED |SDHQ ABS Guards| DZ Tailgate Assist| Onboard Viair 450C AC| Cargo Rail Sys| Stock Exhaust w/turndowns| SDHQ Frame Reinforcement Kit| Outlaw Shock Guards| Mid Perch|ADD Venom Front w/20" Rigid LED Bar & Rear w/Rigid Duallys - Bumpers| Method NVs 17" w/stock BFGs
Blind1 is offline   Reply With Quote
Old 04-12-2012, 07:26 PM   #3 (permalink)
Wilson's Avatar
Welcome
2018 calendar link >http://www.fordraptorforum.com/f16/2...ictures-54101/
Jeff Ethanol I use it
2012 #3105 Diablosport tune aFe stage 2 SW Headers Xpipe true duel S-type muffler 361rwhp
Wilson is offline   Reply With Quote
Old 04-12-2012, 07:27 PM   #4 (permalink)
NickPic83's Avatar
Good to see u guys here. I am on rzrforums too lots of guys with utvs run their lights and love them. Good to have some more good vendor options here!
Sent from my DROID RAZR using Tapatalk 2
I.B.E.W. L.U. 363 Journeyman Foreman Electrician
2012 Silver Screw Saints Offroad Front Bumper, mid perch, Retrofits 3" FXR w/ Evil Eyes, SW long tube headers, lightning style exhaust, 5 Star Tunes on SCT Livewire TS, Injen CAI, Method DS black w/ machned lip, lots of LED lights, LED tails, Hornblasters kit, WSI springs, RPG PSR w/cooler & filter, etc...
NickPic83 is offline   Reply With Quote
Old 04-12-2012, 07:30 PM   #5 (permalink)
Thanks for all the support guys we really appreciate here at Baja Designs.
BD
760-560-2252
Blind1 likes this.
www.bajadesigns.com
-Bailey, Baja Designs
Old 04-13-2012, 12:52 AM   #6 (permalink)
6.2
Banned
some great info up there! and welcome folks, good to see more lighting vendors.
6.2 is offline   Reply With Quote
Old 04-20-2012, 05:03 PM   #7 (permalink)
ARRAPTOR's Avatar
i have two squadron lights mounted at the back corners of my 2012 screw on brackets i got from Outlaw raptor,http://www.outlawraptor.com/23914/40...ht-mounts.html they are so little but so awsomely powerful. i LOVE THEM!!!
got two more coming on an UA bumper from WICKED PERFORANCE. CAN'T WAIT!
THESE R AWESOME LIGHTS!!!!
LIVE ON THE EDGE....BUT DON'T FALL OFF!!!
4 BAJA DESIGN SQUADRON LIGHTS
ARRAPTOR is offline   Reply With Quote
Old 04-24-2012, 05:57 PM   #8 (permalink)
DirtNasty's Avatar
Do you guys do any amber led bars? (or your squad's in amber?)
DirtNasty is offline   Reply With Quote
Old 05-10-2012, 01:31 PM   #9 (permalink)
Yes, we do have amber polycarbonate replacement lenses for our Stealth LED Bars and Our Squadron 3x3. They work great in dust conditions. Please let me know if you have any questions.
Thanks,
BD
www.bajadesigns.com
Tags
hid, led, led light bar, lighting
Please Welcome Baja Designs to FRF! BIRDMAN Baja Designs 20 11-05-2012 08:21 PM
Lighting Guide. Choose the Best Lighting for You Maxx2893 Ford Raptor Lighting Modifications Forum [GEN 1] 28 10-23-2012 05:59 PM
20" Baja Designs Stealth LED RaptorAddict.com Raptor Addict 3 11-20-2011 06:59 PM
Baja Designs Doulbe 20" Stealth LED Bar on Ford Raptor Baja Diego Ford Raptor Lighting Modifications Forum [GEN 1] 14 09-26-2011 06:08 PM
Rigid Light Bar vs. Baja Designs LED XPG RaptorAddict.com Ford Raptor Lighting Modifications Forum [GEN 1] 1 06-13-2011 11:23 AM
