COMPLETED (M&R unveils fog light kit)
MandR Automotive
Well here you have it. The M&R fog light kit is complete.
You can go ahead and start ordering. We decided to sell this awesome product for just $450. Approximate shipping date will be (7/1/12-7/7/12)
This particular kit comes with a bracket that is attached to factory bolts on your bumper frame. They have a waterproof, vibration proof design which enhances the durability of the product. This particular model has three lights on each side with 1 LED which is 10W . These high output LED's produce a lot more light when compared to conventional 1W or even 3W led devices. This kit produces well over 5000 lumens in SPOT, FLOOD, and any combination that a customer wants. It will come for both sides of the truck (6 lights total)
Wanted to provide a DIY installation for you guys to see how easy it will be to install.
Here is the picture of the stock opening of the Ford F150 Raptor
If you look underneath the bumper you will find a bracket which connects the front bumper to the frame of the car.
Go ahead and unscrew the 2 bolts from the bracket. You will need a 10mm socket and probably a 10mm wrench
Here is a picture of the bracket which M&R designed for the truck. It is made out of 1/8" steel. For people who don’t understand the thickness, this is very sturdy and will limit vibration.
Now attach the lights to the bracket. Notice how we used filler nuts as spacers to stagger the height of the lights. The most inward light has 2 extra nuts, the middle one has 1 nuts, and the outer light doesn’t have any. This is what gives it a dropdown effect to flow with the rest of the truck.
Now lift up the bracket from the bumper plate and place M&R fog light bracket aligning the holes between the frame, bumper, and the bracket.
Screw both of the bolts back like it was before
Here is a picture how the lights sit behind the bumper
Here is a picture of both sides being installed
Here is how the staggered effect looks like
swoop1156
USA
Looks good, but for those that have more smarts than common sense, you do not have multiple bolts to stagger the lights. You have nuts that give the staggering in height. You know someone on here would be like, "I can't get more than one bolt in the hole!"
Yeah yeah, bring on the perverse jokes...I know they're coming. Oh look, there's another one.:crazy:
MandR Automotive
MandR Automotive
HAHA thanks i fixed the wording
6.2
Banned
Canada
oh, you're one of THOSE guys....
always thinkin they're better than everyone else cause they catch a mistake.
PFT.
:rofl:
product and mounting looks good M&R, nice product!
NickPic83
Rockland County NY
Can i see a pic from the same angle and distance of your 1st pic but with the lights installed?
Sent from my DROID RAZR using Tapatalk 2
