Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor How-To's and FAQs
Wire Raptor AUX upfitter switches
This is a discussion on Wire Raptor AUX upfitter switches within the Ford Raptor How-To's and FAQs forums, part of the Ford Raptor Forums - General Information category!
Originally Posted by RDFTS Using a higher load on #3 and #4 will melt the wires and cause a fire ...
Like Tree158Likes
Old 10-12-2016, 04:52 PM   #261 (permalink)
carlschmarl2's Avatar
Originally Posted by RDFTS View Post
Using a higher load on #3 and #4 will melt the wires and cause a fire if you put a higher fuse in it. Just use the lower switches to a larger relay then to better grade wire to handle the load. I have a 40" Baja Designs pulling over 21amps at start up connected to aux 3. Have 10 gauge for the light though
So, you have a relay switch between the wire which comes through the firewall into the engine compartment, and a heavier gauge from the light?
What kind of relay are you using?
And how does the relay prevent the wires from melting/burning?
2013 Flame Blue Screw 801A - Icon 3.0's, *RUSTED OUT Rogue Racing Front Bumper*, Two 40" Radius Light Bars, Methods, Vince Center Caps, Pro Comp 315/70R17 Xtreme MT2, MBRP Dumped Exhaust, General Springs in Rear
SnoBall 14, 15, & 16 - Time Attack 2014
carlschmarl2 is offline   Reply With Quote
Old 10-12-2016, 08:26 PM   #262 (permalink)
RDFTS's Avatar
aka Rick
AUX 3 is like 16-18 gauge wire I think. All it is doing is powering the relay that I installed. It doesn't need much to do that, way way less than the rated 15amps. So we have no heat issues here. Again all it does it turns a relay on or off.
Its the standard 87 relay. From that relay that powers the light is where I used 10 gauge. Yes over did it some but for the cost like my wires to stay cool. So power is running from the power terminal off the fuseblock to the relay, on that wire I have an in-line 30amp fuse. From there I am using the same 10 gauge wire to power the light.
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR 14'/15'/16'/17' | Raptoberfest 14'/15'/16'/17' | Time Attack 14' | Snoball 15' | AR Run 15' | TRR Baja 16' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 10-26-2016, 04:42 PM   #263 (permalink)
Junior Member
Default OMG
Very helpful! Thanks for the post. Still the most horrible thing I've had to do in months.. wtf was Ford thinking with this set up? I guess we'd all be happier with 2 more inches though...
RonLWilliams is offline   Reply With Quote
Old 11-01-2016, 05:02 PM   #264 (permalink)
That is correct, is very tight there.
tossty is offline   Reply With Quote
Old 11-15-2016, 05:28 PM   #265 (permalink)
Am I able to run 3 separate lights through 1 switch? Each one draws less than 3A and I'd run though upfitter 1 or 2, those are the ones I currently have available. I know the amperage is significantly less than max but will there be any issues running 3 hot wires to just 1 pass-through wire? As in, will they short each other out or something??
BGA23 is offline   Reply With Quote
Old 12-17-2016, 02:13 AM   #266 (permalink)
Junior Member
You know, I'm dealing with this same pain-in-the-ass light wiring process and getting a fuse that keeps blowing on AUX 2.
Because of that I've busted out the wiring diagrams...
What I don't understand is why in the hell we're using the short connections under the passenger dash with pass thru wires anyways. Why not just go straight from Pin 5 of the Aux switch relays in the Relay box on the driver's side engine bay?
It's the same exact wire that comes from that pin, with the harness, over to the interior passenger kick panel to be spliced with the pass thru wires...
I think I might make myself up a little harness and test it out tomorrow. It looks like it's as simple as popping out the factory wire / pin 5 from the corresponding aux relay connector, and popping in my own to go straight to my light.
Shit, if it works and anyone is still doing this nonsense of the pass thru wires I'll custom make some for those who want to go this route. If I have time tomorrow I'll post up the electrical diagrams and some pics of what I'm talking about.
Mike175 and Mluis11 like this.
Verruckt is offline   Reply With Quote
Old 12-20-2016, 01:36 AM   #267 (permalink)
Helibike's Avatar
Junior Member
Default Upfitter switch stopped working
This post was really helpful for me, until.....
My Upfitter 1 switch stopped working after a couple days though. No lights and no power. Good fuse and good relay. Good connections. What is going on??
Well, pulled apart the console and found the microswitches had Starbucks froofy sticky coffee residue in them (previous owner). This combined with the cold weather caused one of the little forks on the inside of the switch to crack. The little fork couldn't flip the microswitch. No yellow light, no power.
So a little hi end CA and put it back together. Careful because the fork is right where the switch pivot is and you can break the fork again putting the switch back together.
Hope these pics help someone. The upfitter switch pod is about $90 and this fix is essentially free.
Wilson and 2014RubyRed like this.
Cheers,
Helibike is offline   Reply With Quote
Old 12-20-2016, 12:12 PM   #268 (permalink)
Originally Posted by BIRDMAN View Post
Yes, again. This time with more pictures and *hopefully* simplest instructions yet.
1. Choose your upfitter switch based on the current draw your lighting device creates. To determine the amperage, divide the wattage of the device by 14.4v. Amps = watts/volts
From the factory the switches are fused as follows (Fuse # in under hood fuse/relay panel):
AUX 1 30A (#18)
AUX 2 30A (#19)
AUX 3 15A (#44)
AUX 4 10A (#28)
2. Remove the dash panel on the passenger side by pulling straight out. It's made easy by grabbing on to the vent hole and giving a gentle pull. Remove the panel and put aside.
3. Release the glove box by opening it and pulling in the box sides to clear the rubber stops. The glove box will just hang down.
4. Take a look inside toward the right the glove box opening. You will see 8 dead end wires. Based on which AUX switch you have chosen to use, locate the corresponding wire and strip it (make sure the switch is off of course). The +12v power comes from these wires.
AUX 1 Yellow
AUX 2 Green with Brown tracer
AUX 3 Purple with Green tracer
AUX 4 Brown
5. The other 4 wires you will see - Green, Blue, Purple and Red are the "pass through wires". One end of them is behind the glove box, the other end is under the hood near the firewall on the passenger side. These wires are "passed through" the firewall for your convenience. They do not directly correspond with any switches, they are just there to use. You simply pick one of the wires, connect your corresponding AUX switch wire to it with a crimp connector (or solder, but this can be difficult based on the limited space), and move to under the hood.
6. Under the hood you will see the other ends of those 4 pass through wires - Green, Blue, Purple and Red. Whichever wire you connected your AUX switch wire to is the one that is now energized +12v (when the switch is on) and the wire you should use to run to your device.
From the factory, the pass through wires are taped to a wiring harness. Pull out the one you picked and proceed with your wiring.
*Example: If I want to use AUX 1 to power my 40" LED light bar, I will need to use the Yellow power wire that corresponds to AUX 1. I can connect the Yellow wire to any of the Green, Blue, Purple or Red pass through wires behind the glove box. Let's say I picked to use the Red pass through wire, now I am going to hook the positive wire from my light bar to the Red wire under the hood.
7. Once you have run more primary wire from the pass through wire under the hood to your light, you can move on to grounding the light. You can choose any of the factory grounding points that are very conveniently located near the pass through wires. I recommend just using a ring terminal and bolting under the factory ground point.
8. With your wiring complete, using some flex conduit and zip ties will clean up your work. Proceed with all connections and securing wiring using good automotive wiring practices to avoid any future issues.
That was a really good post!!!!! I was thinking about adding some fog lights to my Gen2 when I get it, but I wasn't sure how to go about doing it. Seems like a fairly simple process thanks to you!!!!
Jeff-Ohio is offline   Reply With Quote
Old 10-11-2017, 01:14 AM   #269 (permalink)
M32
Awesome. Very helpful
M32 is offline   Reply With Quote
Old 10-31-2017, 11:34 AM   #270 (permalink)
KRoyal's Avatar
Very helpful. Exactly what I was needing glad I searched before I asked.
KRoyal is offline   Reply With Quote
Upfitter Switches Iron Creek Ford Raptor Audio/Video/Electronics Forum [GEN 1] 15 09-15-2014 05:52 PM
Relo upfitter and two round switches shannondavis Ford Raptor Problems and Questions Forum 0 11-11-2012 10:09 PM
Another crazy idea for upfitter switches Squatting Dog Ford Raptor Audio/Video/Electronics Forum [GEN 1] 9 08-17-2012 11:55 AM
how to wire upfitter switch 1 to 10 amp fuse? matt33 Ford Raptor Lighting Modifications Forum [GEN 1] 5 05-14-2012 11:51 PM
Upfitter wire access? BigJ Ford Raptor Audio/Video/Electronics Forum [GEN 1] 7 03-23-2010 03:25 PM
