Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor How-To's and FAQs
Upgraded upfitter switch's
This is a discussion on Upgraded upfitter switch's within the Ford Raptor How-To's and FAQs forums, part of the Ford Raptor Forums - General Information category!
After using all my stock Upfitter switch's I started to work on adding more. I bought a complete upfitter assembly ...
Like Tree1Likes
  • 1 Post By JAYBIRDNLV
Old 05-12-2013, 09:57 AM   #1 (permalink)
JAYBIRDNLV's Avatar
Default Upgraded upfitter switch's
After using all my stock Upfitter switch's I started to work on adding more. I bought a complete upfitter assembly from Ford hoping to add just the switch assembly, however it is too large. Since all of my lighting options are from RIGID.. I have all these extra switch's and wiring harnesses laying around and decided to put them to good use. I added a fuse block under the hood wired directly to the battery to handle all the fuse locations in one place. Here is the contact info , I got the one that has six fuse locations.
( K4 :: Provider of top quality switches since 1975 )part # 19-133. Mounted it to a piece of sheet metal, painted and trimmed edges to the fire wall.
I will post more pictures and info later if needed.
reid_88 likes this.
FOX 3.0's F & R / ICON UCA's /RPG tie rods/ RPG 2.5 Bump stop w/HD+2 National springs/ Rigid 20 in & 6 D2 Duallies / Outlaw Alpha 1 Tire Rack / Yeasu race radio / HDS Gen2 / Outlaw Trans Cooler / SDHQ Hood lite / Tuffy lock Box/ CORE Trac tie down system/ Method NV polished / BFG's
JAYBIRDNLV is offline   Reply With Quote
Old 05-19-2013, 01:42 AM   #2 (permalink)
Tommysyko's Avatar
Looks pretty sweet. You might have to get a unitrol from an emergency vehicle if you add more
Tommysyko is offline   Reply With Quote
Old 05-19-2013, 09:19 AM   #3 (permalink)
MTUH3's Avatar
Cool, does that box also include space for relays? How / were did you put the relays? I have been trying to decide if I want to just buy a fuse and relay box from a place like Painless Performance, or just build my own. There is another on-line electrical company, but for the life of me I can't remember the name. I will have to dig through my email.
Carl - Plymouth, MI
2011 Super Crew - MRT Exhaust, Front Icon 3.0 Coilover, Rear Fox 3.0 shocks 2.0 bumps, Hellwig rear sway bar, SVC Upper Control Arms
https://www.facebook.com/RogueWaveIndustries
MTUH3 is offline   Reply With Quote
Upgraded IWE Squatting Dog Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 261 01-31-2018 04:53 PM
Headlight switch with fog light switch Shortbusdriver Ford Raptor Lighting Modifications Forum [GEN 1] 1 04-14-2013 01:16 PM
upfitter switch to toggle switch stsmith03 Ford Raptor Audio/Video/Electronics Forum [GEN 1] 0 05-16-2012 11:51 AM
how to wire upfitter switch 1 to 10 amp fuse? matt33 Ford Raptor Lighting Modifications Forum [GEN 1] 5 05-14-2012 10:51 PM
Upfitter / Aux Switch Wiring Explained BigJ Ford Raptor Audio/Video/Electronics Forum [GEN 1] 12 01-27-2012 10:20 AM
