Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor How-To's and FAQs
Install F150 Headlight Switch fog / driving lights
This is a discussion on Install F150 Headlight Switch fog / driving lights within the Ford Raptor How-To's and FAQs forums, part of the Ford Raptor Forums - General Information category!
I installed some SuperDuty driving / fog lights on my Raptor and was not wanting to use up one of ...
Like Tree37Likes
Old 01-27-2013, 05:26 PM   #1 (permalink)
SVT_4X4's Avatar
Default Install F150 Headlight Switch fog / driving lights
I installed some SuperDuty driving / fog lights on my Raptor and was not wanting to use up one of my Upfitter switches, so decided to install a regular F150 headlight switch which would be for a regular F150 with driving lights. I have a 2012 Raptor with automatic headlamps, but think these instructions could help people with other years. The switch I purchased was for a 2012 F150 with automatic headlamps and driving lights. I also had to purchase a pigtail plug for the extra wires for the fog lamps. Ford uses this same pigtail for many areas of the vehicle, and least expensive I could find was eBay. I bought the Motorcraft WPT-934 pigtail.
Wiring Diagram
I cut off the old headlight pigtail and installed the new one. I did this one wire at a time.
The wires off to the right are the stock light wires, then I have the fog on the left.
Basically how this wiring in the switch works is once the fog light switch is turned on by pulling on the switch, it send a ground signal to the lights. So I installed a relay out next to the Outfitter switch relays. So this ground signal from the headlight switch runs outside to that relay. I pulled the power from that relay also from the feed into the Outfitter switch relays. Then the second wire you see on the headlight switch pigtail is to show when the fog lamps are on, so the output from the new fog light relay runs to the two lights, but also runs back to the headlight switch which turns on the little light on the switch.
For the bumper I had to cut some of the metal off from the mounting brackets on both sides. I bough some SuperDuty lights and cut the plastic brackets down and made up some metal brackets to mount them.
I like being able to run these on the street and it seems to light up the road very nicely.
Clayton Parks - Michigan
formerly cparksjr
2012 Ford Raptor SuperCrew / 2014 Explorer / 1957 Ranchero / 1960 F250 / 2014 CanAm Maverick Max
SVT_4X4 is offline   Reply With Quote
Old 01-27-2013, 06:06 PM   #2 (permalink)
Reptar's Avatar
AWESOME mod!!!!
I almost want to do this and just hook that light up to the factory headlights. It drives me nuts that the factory headlight switch isn't illuminated at that white stripe. I can never tell at dawn or dusk if my headlights are on or not. Dark enough I can't see the stripe on the knob, but light enough outside I can't tell if the lights are on or off.
Can you post bigger pics of the wiring diagram, and the part number for the headlight switch?
Also how does the switch pop in and out?
mike.s likes this.
REPTAR - 2012 SVT Raptor Supercrew, Ordered 08/26, VIN'd 12/15, Sch'd DAY of 1/19
M.HYDE - 2000 HD F-150 #0356 of 8197, 789/871, 09.88 @ 139.66
D.JEKL - 2000 HD F-150 #1552 of 8197, 372/450, 13.59 @ 100.95 - SOLD
GEN.0L - 1985 XL F-150, 1994 Lightning 5.8L Donor Engine Swap
Reptar is offline   Reply With Quote
Old 01-27-2013, 06:16 PM   #3 (permalink)
J DAMAGE's Avatar
Great job, good write up, here's a question, looks like the new plug has more wires than the one installed, but are the same plug, couldnt we just buy the factory switch and add the wires needed, looks like empty/open spots in the factory installed plug? giving room to exspand.
wheresaldo likes this.
J DAMAGE is offline   Reply With Quote
Old 01-27-2013, 10:04 PM   #4 (permalink)
Dv8tor's Avatar
I would be surprised that our trucks aren't pre wired for fog lights. I had an 04 ram that didn't have fog lights. I got a switch, found the fog light harness sitting behind the front bumper plugged th foggies in, bam. I had fog lights. I would love it if someone found the fog light harness on our trucks hiding somewhere.
I am an attention whore
Dv8tor is offline   Reply With Quote
Old 01-27-2013, 10:15 PM   #5 (permalink)
SVT_4X4's Avatar
Nope they are not at all. I know with the older systems they used to do some of that, but this does not have any of the fog light wiring at the switch, or at the main fuse box multi function box which is behind the passenger kick panel.
---------- Post added at 10:12 PM ---------- Previous post was at 10:11 PM ----------
Yes you are correct there are empty open slots, but unlike other plugs I am have used in racing like weatherpack, I could not see how to pull the wire and terminal out of these without destroying them and the plug. But if you can figure that out, it would speed up the process.
---------- Post added at 10:15 PM ---------- Previous post was at 10:12 PM ----------
Originally Posted by Reptar View Post
AWESOME mod!!!!
PM me your email address and I can email you a PDF of the wiring diagram. Trying to remember on the switch it was 2 months ago when I did this. As I recall you remove that side panel on the side of the dash by the door, and get your hand in there and some clips to push in and the switch just pops out the front.
formerly cparksjr
Old 01-27-2013, 10:36 PM   #6 (permalink)
CoronaRaptor's Avatar
Nice mod and it looks good
CoronaRaptor is offline   Reply With Quote
Old 01-28-2013, 07:46 AM   #7 (permalink)
Reptar's Avatar
harley356(AT)gmail(DOT)com
It'd be great if we could just source the pins, but that can be a PITA if the connector is unknown.
Thanks for this how-to, it's a great idea!
Old 01-28-2013, 04:38 PM   #8 (permalink)
phydough's Avatar
Are the pinouts the same for both plugs? Minus the additional two.
phydough is offline   Reply With Quote
Old 01-28-2013, 06:46 PM   #9 (permalink)
SVT_4X4's Avatar
The pinouts are the same between both switches, just the stock Raptor switch and plug does not have the extra wires for the fog / driving lights.
formerly cparksjr
Old 01-28-2013, 07:47 PM   #10 (permalink)
MTUH3's Avatar
You beat me to it. This is exactly what I was going to do in the next couple weeks!
Carl - Plymouth, MI
2011 Super Crew - MRT Exhaust, Front Icon 3.0 Coilover, Rear Fox 3.0 shocks 2.0 bumps, Hellwig rear sway bar, SVC Upper Control Arms
https://www.facebook.com/RogueWaveIndustries
MTUH3 is offline   Reply With Quote
driving lights Danactive Want to Buy 0 09-17-2012 05:34 PM
Standard F150 Light Switch (knob) retrofit EatsPrii Ford Raptor Lighting Modifications Forum [GEN 1] 9 05-25-2012 09:01 PM
Driving lights installed JMic Ford Raptor Photos & Videos 4 10-01-2011 09:54 PM
Daytime driving lights First Truck Ford Raptor Lighting Modifications Forum [GEN 1] 15 08-07-2011 11:48 AM
Hella Xenon Driving lights Install BajaRider Ford Raptor Lighting Modifications Forum [GEN 1] 29 02-27-2011 05:38 PM
