DDM Tuning retrofits
svtchris1021
Calexico, CA
I finally made my retrofit 2 months ago, lift output is waaay better than factory and hids on oem housing. Almost look like oem headlight, difference is that this kit is around 100 bucks
Kit includes:
2 DDM v3 projectors (2.5) (lifetime warranty)
2 shourds
H1 bulbs, got myself 5500k pure white
Totaled out $97 :)
I pre heated the oven to 230 degrees, and did 3 cycles of 10 mins, it was my first time doing this so I was kind of afraid, I woukd say its pretty damn easy, put the headlight on the oven for 10 mins, took it out ( wear some mechanic gloves cause its HOT) and with your skinniest flat head start prying section by section, when it feel cold again stick it for another 10 min, ( total of 3 times for me)
projectors are bolt on, the only this that need to dremel is the little mount were the ford cap goes, once you do this, projector sits perfect. I decided to go all black, so i used the high heat flat black paint :) no chrome for me!
Before resealed everything together you have to aling the beams, park your truck 25ft from a clear wall , make sure is straight, dont have to move anything on the headlight just straight out the beams :)
to resealed put the headlight cover back on top and stick it in the oven for 5 -7 min this will make soft the silicone and bow you can compressed it down, make sure the tabs around the headlight sit tight, i used clear rtv silicone around again, and let it dry over night :)
Bulletnjm
New Jersey
Cool, one more question while the cover is off i can assume you could tint the orange marker correct?
tahitiansoul
Tahiti
Thanks for the link. For the shroud, which one did you choose? did you have to drill some holes to mount the projector (nuts)?
Any pictures installed on truck?
