Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor How-To's and FAQs
Change Fox Bump Stop Pad for Towing
This is a discussion on Change Fox Bump Stop Pad for Towing within the Ford Raptor How-To's and FAQs forums, part of the Ford Raptor Forums - General Information category!
I also have a set of HD nationals for sale they are great for towing. I just need a different ...
Like Tree8Likes
Old 10-14-2016, 04:02 PM   #11 (permalink)
Hole Shot's Avatar
Default Change Fox Bump Stop Pad for Towing
I also have a set of HD nationals for sale they are great for towing. I just need a different setup for my bypass rack.
Hole Shot is offline   Reply With Quote
Old 10-14-2016, 06:52 PM   #12 (permalink)
Yukon Joe's Avatar
You can't just jump in on my potential sale like that, buzz off one arm bandit dude!
@Yukon Joe
Drive your raptor here!!!!
www.runraptorrun.com
( * Y * )
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 10-14-2016, 07:31 PM   #13 (permalink)
Trick_Raptor's Avatar
The Cracker Raptor
After going to Deaver +2 and the RPG bumpstop kit with my toybox I was just barely off the bumpstop and when I did hit it was rough. I didn't like the ride either when hitting the bumpstop.
I re-arched to +3 with a load leaf and now I sit a little over 2" from the bumpstop even with a rack. With even more weight in the rear plus my toybox I was still 1.5" from the bumpstop and not once over 1000 miles did I hit it.
With the pic above I was at 15,080lbs. which was 380lbs over max weight. The trailer was at 7000lbs and the rear axles 4540lbs and 3540lbs on the front. The ride was amazing and no need for the bumpstops.
I have the extensions on sale for $49.99 :) Save yourself some money!
Trick_Raptor is offline   Reply With Quote
Old 10-14-2016, 07:58 PM   #14 (permalink)
Hole Shot's Avatar
Your bump extensions and my springs and he will be set.
Yukon Joe likes this.
Old 07-20-2017, 02:09 PM   #15 (permalink)
Sorry for digging old post up... but is your suggestion is to keep the shorter bumpstops & +3 springs for optimal setup? Or is it to not use the BS for towing at all?
Thanks!
Trick_Raptor likes this.
vr4henry is offline   Reply With Quote
Old 07-20-2017, 05:03 PM   #16 (permalink)
The Cracker Raptor
Thanks!
I never used the the bumpstop extensions so I can't say if they are the better choice. When at +2 I would be riding on them and didn't like that idea.
While I only tow my trailer on average four times a year the +3 and load leaf pay off. They also pay off while off-roading as I carry about 500lbs of gear in my bed yet my Raptor still rides with the factory stance.
Just finished a 811+ off-road adventure on the ROC Pony Express run. The rear end was planted and rode great the whole time :)
Old 07-20-2017, 07:06 PM   #17 (permalink)
Awesome shot!!
Did you have to custom order the +3 with load leafs? I think I'll end up with a similar setup to yours. Skipping the bumpstops would certain save some $...
If you did it all again, would you skip the BSK and just do load leaf and +3s?
Old 07-20-2017, 07:28 PM   #18 (permalink)
The Cracker Raptor
Awesome shot!!
You can order directly from Deaver anything you need. In my case I originally bought Deaver +2 from WOG (Westside Offroad Group) and when that didn't go the way I wanted I went directly down to Deaver in Santa Ana, CA to have them re-arch to +3 and add the load leaf.
I might have misunderstood you about the bump stops, the RPG kit comes with bump stop extension pads and I never ran anything other than the smallest one pictured below.
As for the bump stop that was the very first mod I did. It makes a huge difference off-road and I always recommend to ROC participants out on runs to get one.
Old 07-20-2017, 09:48 PM   #19 (permalink)
Got it -- thanks for advice! I'll be copying your setup with bumpstops (at short setting) and +3 springs as I tow a few times a year and have a camper shell on the back.
which bump stop kit did you go with??? jackrook Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 193 12-02-2014 07:12 PM
RPG Bump Stop Kit bstoner59 Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 23 12-08-2011 08:15 PM
ADD/King bump stop kit is on SOCOMech Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 17 10-12-2011 08:43 PM
bump stop replacement debate Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 15 07-01-2011 09:42 AM
Bump Stop Question.... odn13x Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 7 12-18-2010 12:23 AM
