Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor How-To's and FAQs
Bed Bolt Removal
This is a discussion on Bed Bolt Removal within the Ford Raptor How-To's and FAQs forums, part of the Ford Raptor Forums - General Information category!
So you got your Raptor and you succumbed to the peer pressure of all the cool stuff and agree that ...
Like Tree30Likes
Old 05-06-2015, 11:34 PM   #1 (permalink)
The Macf's Avatar
Default Bed Bolt Removal
So you got your Raptor and you succumbed to the peer pressure of all the cool stuff and agree that Ford didn't do us any favors with the four meager and useless tie down hooks. So what do you? You buy or fabricate (good for you ) a bed rack. The first step though is getting the bed bolts out. There are six of them by the way.
Step 1:
Get some PB Blaster or some other rust penetrating lubricant and soak that shit overnight. Seriously. Use a WD-40 straw and get under the cap and washer and let it soak down the bolt. Then go under the bed and spray the nuts. Get in there real good, don't be afraid to get dirty.
Step 2:
Procure yourself a Torx Plus 50 (TP50) $9.70 at Napa Parts. Not a Torx 50, a TORX PLUS 50
You can see the difference:
Now hopefully you followed step one and let everything soak and they should break free. Use your shiny new tool and go to town. Remember righty tighty, lefty loosy. If everything went according to plan, you should have 6 bolts rolling around and hopefully they don't look like this:
Thank you road salt.
In the event that you stripped one out or broke one you're going to want to get yourself one one of these. Very handy. $36 at harbor freight for both.
Use the normal drill bit and get it started. Once you have a decent pilot hole, use the goofy screw and the T tap and slowly apply pressure. Equal force is the key, if you go one sided it will twist and fall out. Then you get to start all over.
Now that you've got your broken bolt out, you'll need a new one. These are $18 a piece at your local ford or $10 online.
When you're ready to put your bolts back in, do yourself a favor and spray out your bed holes with wd40 or anti seize or something to prevent this from happening next time.
Hopefully everything goes smooth and you end with something like this.
Remember Torx PLUS 50 and Ford calls them mount bolts for some reason.
Cheers
Chris
IRONMAN, MTF, Ruger and 10 others like this.
The Macf is offline   Reply With Quote
Old 05-06-2015, 11:53 PM   #2 (permalink)
Raptizzle's Avatar
FYT
Approved?
Gen 2 Raptor Equipped With:
SVC Offroad
KING Race Shocks
DEAVER Suspension
Raptizzle is offline   Reply With Quote
Old 05-07-2015, 12:06 AM   #3 (permalink)
RDFTS's Avatar
aka Rick
I would add to your FAQ, the correct torque on the bed bolts?
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR & Raptoberfest 14'/15'/16'/17'/18' | Time Attack 14' | Snoball 15'/18' | AR Run 15' | TRR Baja 16'/18' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 05-07-2015, 12:15 AM   #4 (permalink)
Zeke555's Avatar
Planning on getting an XRD bed rack so this was excellent information to have ahead of time.
Zeke555 is offline   Reply With Quote
Old 05-07-2015, 07:44 AM   #5 (permalink)
The Macf's Avatar
The Internet says anywhere from 46-68
A.I.I.Raciing likes this.
Old 05-07-2015, 08:08 AM   #6 (permalink)
Bulletnjm's Avatar
Nice write up, i have beeen wanting to remove my bed bolts
Bulletnjm is offline   Reply With Quote
Old 05-07-2015, 08:44 AM   #7 (permalink)
RDFTS's Avatar
aka Rick
According to the thread that @pirate air started, the Ford specs is 59lb. And it shows these bolts should be discarded and replaced when removed.
MTF and Rodbender like this.
Old 05-07-2015, 08:53 AM   #8 (permalink)
The Macf's Avatar
Suggested.
Everything is always up to the owner. I chose to use new bolts.
Old 05-07-2015, 09:11 AM   #9 (permalink)
Ruger's Avatar
Okay, I'll bite. Bolts that area whopping $18 each ought to be tough enough to be reusable. Any clue why Ford recommends that they be replaced?
"Free men do not ask permission to bear arms." - Thomas Jefferson
"I like my coffee black, and my tea in the harbor." - Jay Posey, author
Ruger is offline   Reply With Quote
Old 05-07-2015, 09:16 AM   #10 (permalink)
The Macf's Avatar
So they can make more money when you use your standard torx 50 and strip them out. Couldn't tell you honestly. It's not like they're made out of soft steel, they're holding down your fricking bed.
Ruger and RDFTS like this.
RPG Bolt on LT Kit biggiebigs Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 168 11-12-2017 11:06 AM
DIY: Bed Bolt Removal With Factory Liner + Extra Tie Downs BearLeeAsian Ford Raptor How-To's and FAQs 3 08-31-2015 10:26 AM
SVC 100% Bolt-on ?? Aramco Raptor Ford Raptor Suspension Discussion and Modifications Forum [GEN 1] 1 01-10-2015 12:14 PM
Anyone install Cam Bolt Kit on LCA's GRT4DRT Ford Raptor Maintenance Forum 8 06-02-2011 05:44 PM
