Need suggestions for header and exhaust upgrade
The Macf
Vegas
The SW performance connect(stock exhaust fitting) is two single pipes with just y connection to hook up to the factory muffler. You have to remove the factory resonator and the tubing slides into the muffler. That being said you could buy the SW system and run two muffler turndowns. I believe @MOLONxLABE has this style. Check out his build thread.
Aramco Raptor
Montreal, Canada
Aramco, I'm not sure I get your point. I am going for a completely new system. I just want headers that I can build onto, not be stuck with their y-/x-pipe. Thoughts?
In that case...just get a set of headers and cans and have the rest fabricated...that way you will get what you want.
You mentioned you wanted an H-pipe with dual mufflers...but what I was trying to get across is that at our horsepower, torque and RPM numbers...it wouldn't increase performance...just cost.
A two into one is plenty for the 6.2 application under 500 hp. Above that and in higher RPM ranges...H-pipes and X-pipes start to make a difference.
---------- Post added at 09:50 AM ---------- Previous post was at 09:45 AM ----------
Bullet, I also think a y-pipe would be more restrictive. That is, unless the single outlet tube was at least twice the area of the two incoming tubes. I think an x-/h-pipe would have comparable flow properties to each other. I have no empirical data for this, just an old engineering degree. - YODA
In this case...bigger is not always better. If your outlet diameter is too big...you actually decrease scavenging and therefore actually lose performance. I've done a lot of flow testing of exhaust systems for circle track cars and drag cars and the results are quite surprising.
Mjolnir
Colleyville, Texas
I have the SW LT headers with cats going into a Borla exhaust dumped at the rear axle.
Do not think that in any way shape or form these won't be loud in the cab. People wet themselves when I start up my truck.
https://youtu.be/_MVhiI_heuQ
here is one from inside the truck:
https://youtu.be/x5kBn8Frr54
one more incase you still can't make up your mind:
https://youtu.be/Naf6AGZpM7k
finally, horsepower gains (with tune and CAI) - honestly about 27 hp.
ProjecT 9
Houston
Which rear bumper do you have? Looks real good! Thanks
Jon
Key
Abilene, TX
Stainless works LT headers with custom Y pipe, racing cats, and Corsa xtreme exhaust. No drone, sounds like the world is being torn asunder when I get on it.
ProjecT 9
Houston
Thanks. ADD Raceline R in front and AdD Stealth Fighter in Rear
NP, Post up a pic of the front? I'd like to see it. I'm placing my order for some parts this week with TMX but still undecided on the front bumper. I'm between the Race R, Baja Coyote, and Rogue Throttle. I'm not wanting to cut my frame. Anyway, I'd appreciate it.
Jon
factive
Park City, Ut
In that first video ,you ask if it's normal. I'm pretty sure mine's worse but I live at 6500' in the cold mountains. My cold start lasts 30-40+ seconds. I feel bad for my neighbors. I asked SVC if they could do a cold start delete on my tune but they said it's necessary with the headers.
Yukon Joe
Russellville, AR
I live in NC and mutt cold start usually lasts about 30 seconds. You want the higher RPMs so the engine warms up.
I have both a custom tune and 5Star tune. The 5star tune must have a cold start delete. It's really quite in comparison to the custom tune or even no tune.
Yukon Joe
