Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Exhaust and Cutouts Discussion [GEN 1]
Need Major CAT / Exhaust advice Please!
This is a discussion on Need Major CAT / Exhaust advice Please! within the Ford Raptor Exhaust and Cutouts Discussion [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Just gotta cut em off....
Like Tree8Likes
Sponsored By: Stainless Works
Old 06-05-2018, 09:40 PM   #11 (permalink)
RDFTS's Avatar
aka Rick
Deanwam8 likes this.
2014 RR SE SCREW | #792 of #3396 in RR | #4568 of #22409 Total | My Mods: Click Here
2008 Shelby Mustang GT500 Torch Red Convertible | #58 of #463 in Torch Red | #249 of #2070 Total
Raptor Runs: TRR & Raptoberfest 14'/15'/16'/17'/18' | Time Attack 14' | Snoball 15'/18' | AR Run 15' | TRR Baja 16'/18' | Private Baja Jan 17'
RDFTS is offline   Reply With Quote
Old 06-07-2018, 03:47 PM   #12 (permalink)
Deanwam8's Avatar
Junior Member
@RDFTS I just PM'ed you. Turns out my headers are Borla longtubes. Apparently there is no way to attach cats to them. I was told I will have to remove them and either go with another brand cats/headers (which is way expensive for me now) or go back to stock manifolds/cats. I was told about 8 hours of labor to remove my current headers so this is expensive any way I look at it...Figures...this is one of the worse case scenarios...
Deanwam8 is offline   Reply With Quote
Old 06-07-2018, 05:11 PM   #13 (permalink)
Have you attempted to have the truck inspected yet? If it is not throwing any codes (do you have a check engine light showing?) you might pass.
My build thread: http://www.fordraptorforum.com/f65/w...6/#post1012544
Truckzor is offline   Reply With Quote
Old 06-07-2018, 08:00 PM   #14 (permalink)
Junior Member
I am curious about this as well!
I am searching for my first Raptor and found a nice one several states away. About to go get it and read this thread.....
I ask dealer if it has cats and he says it doesn’t.
So if I decide I want this truck, I will need to put cats on it -or- if it is not throwing codes, then will it pass emissions?
Sunder is offline   Reply With Quote
Old 06-07-2018, 11:10 PM   #15 (permalink)
Deanwam8's Avatar
Junior Member
The check engine light is off I think because it's under tune..but apparently it is throwing 4 O2 sensor codes. I attempted inspection and the problem was that all my monitors were off (again because of the tune I think) so they couldn't complete it. I have Borla long tube headers and a Borla S-Type exhaust with NO CATs. The fact that they are Borla headers totally screws me because apparently there are no CATs that will fit with them in any way..at least that's what I was told by the performance shop in NJ I contacted...as well as Borla. Sucks bad right now.....this mess is going to cost me around $3K+ to fix...
---------- Post added at 11:10 PM ---------- Previous post was at 11:01 PM ----------
If it's not throwing any codes and they can read your monitors...you may pass. I have no idea how that is possible without cats though. Not every inspection place physically checks for them - but I don't know how you can pass without them. This has been my nightmare of an issue for the past couple weeks...so if someone knows of a way, I would love to know lol. What state are you in? Check and see what your state regulations are. If the truck doesnt have cats...then what is on it? What brand of headers? If it's kooks or stainless works..you can actually get away with putting their cats on for relatively cheap. My situation sucks because my Borla headers will not allow for cats ...so I have to have them taken off ($1000+ in labor) and then either another brand of cats/headers or return to stock cats/manifolds...AND then I need to buy a tuner and have it tuned...major bucks that was not in the original plan...my fault for not checking for cats...Thank god you checked my post cause if I were you..I would do a bit more research before closing the deal...and perhaps ask for a concession because of the lack of cats...
Old 06-07-2018, 11:52 PM   #16 (permalink)
Junior Member
I am in Wisconsin. They “outsource” the emissions testing to oil change places and repair shops. They just hook a cable up to the ODB reader. Those guys don’t physically check for cats. The bigger question would be if there are codes being thrown. It has a flow master exhaust.
Argh! I was so close!
The truck is over 800 miles from me, so not easy to test or confirm- and I could be in a similar situation as you!
If I could acquire some stock cats, I could probably add them back on without too much trouble (or not at all if no codes are thrown ).
Exhaust advice JnJraptor Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 13 12-07-2015 10:10 PM
Exhaust Advice - Looking for low rumble chartquist Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 44 07-27-2015 11:21 AM
Exhaust advice needed ZBoater Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 18 11-05-2014 09:55 PM
6.2 Exhaust advice-- Ford Racing, Borla, MF DBell Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 46 10-26-2014 09:49 PM
Between Major Cleaning Fred Ford Raptor Cleaning and Detailing Forum 34 02-21-2013 10:03 AM
