Magnaflow Magnapack with turn down before axle question?
ittybittyfds
Western, MD
"For those of you who have had the Magnapack with a turn down before axle on for while"
1. is there any exhaust fumes in the cabin?
2. has there been any negative effect caused by heat?
3. Any issues while offroading? (rattling)
3. should I position the turn down so that the exhaust flows out towards the side or turn it so its straight down?
I need to replace my flowmaster and I am not looking to brake the bank.
Bulletnjm
New Jersey
For questions 1 & 4 I believe you should have the exhaust pointing down at the ground to keep the fumes going to the ground. I don't believe you will get fumes in the cab as I have read some people have comepletely removed everything from the headers back and said they did not get any in cab fumes. Other than that, I doubt it will raffle as long as it is securely fastened in. This is all my opinion, anyone who has anything to add please feel free.
JJ f150harley
Traverse City MI
No issues with any if ur questions. Just point it toward the ground but the resonance will be loud. Just secure it properly and ur truck will sound like a beast. Had mine since last October.
Sent from my DROID RAZR HD using Tapatalk
ALLOUTWARN
im running that setup, there are no fumes in the cab, it doesn't rattle while offroad, drones a little just under 3k and I have mine pointed down but angled a little towards the passenger side, sounds mean as hell!!
Badrap
Haslet, Texas
Mine is turned down before the axle. Only issue is a lot of drone but, that's what the radio is for. Wonder what diff the resonator delete might make. Can't tell from some of the post I read. Anyway going to headers in a few months.
scoutdrivinrebel
DFW, TX
My drone isn't bad, but mine does go just over and past the axle and turn down. I think it sounds great that way. No fumes, no rattles...limited done.
NickPic83
Rockland County NY
i ran this exact setup with a turn down tip. no issues at all except it had pretty bad drone. the resonance was too much for me. i had a lightning style exit made up which helped eliminate some of the drone
ALLOUTWARN
I def. would have to say running the magnapack dumped with resonator delete is prob the gnarliest yet still clean these trucks sound besides running long tube headers and hi flow cats. When you uncork it sounds like a race truck!
