chartquist
Looking for advice... there are tons of threads here on which cat back exhaust is best, but I haven't seen much on the best way to attach the new exhaust to the pipe from the cat. I plan to delete the resonator. Is it best to just line them up dry and tighten the bolts down? Should I put in an exhaust gasket or use Copper RTV on the joint? Should I use red Loctite on the bolts? Finally, how much should I tighten the bolts? I want to avoid any leaks at that joint and I sure don't want the bolts to come out. Also want to make sure they can be removed if I ever want to switch back to the stock exhaust for resale, etc. Thanks.
