Dump exhaust question
dhanni848
Nashville, TN
I searched and PM'd someone with no response so thought I would ask here.
I just picked up a 2011 SCREW, and it is actually straight piped for now. I have watched many videos for Raptor exhuasts, and it really sounds good to be honest.
The question is, has anyone done an exhaust dump after the rear axle near the factory hanger, and not had to go to a shop to have a new hanger piece welded? When I looked at it the factory hanger is only welded to 1 of the exhaust pipes, or mine is anyway.
I would like to just cut it myself as long as I can do that and get no rattle or movement.
Thanks!
Wilson
South Dakota
are you sure the pipes are not welded together. I have not herd of anyone that has done this mod complain.
Mjolnir
Colleyville, Texas
Thanks!
mine is dumped at the rear axle, and I have kept the stock hanger, just ran 250+ miles at the Raptor run and no issues at all (for the 8th event). my only issue was my SW headers broke at the Y into the exhaust, a known weakness, that has been fixed with a new welded on bracket.
here's some old pics showing it:
dhanni848
dhanni848
Nashville, TN
Awesome and very good to know! I will have to take a look again, and maybe post a picture to confirm as well. I really thought I only saw the hanger welded to 1 pipe. I didn't look to see if the actual pipes were welded together however.
I just hate the tips on this thing :(
Mjolnir
Colleyville, Texas
Just looked under mine
You have a hanger on the exhaust canister, then one on the driver's side pipe right before the upturn over the axle. but like I have said, I've run this thing over about everything and never had a problem from that end.
i was okay with tips, but for off roading i didn't want anything in the way, this tucks it up and makes it go away. because you're dumping under bed, it gets loud AF under there.
dhanni848
dhanni848
Nashville, TN
It sounds great right now (a bit loud, but I like it). How much louder are we talking here! I didnt look in from of the axle so that explains it. I am good to go then.
Mjolnir
Colleyville, Texas
dhanni848
dhanni848
Nashville, TN
