6.2 exhaust recommendations
Hopscotch
NW Ohio
All jokes aside. I have a Black Widow with the stock resonator and it sounds good. Minimal drone and solid tone. I personally like the sound of a chambered muffler vs a fiberglass packed muffler.
Which black widow and what do think it would sound like without the resonator?
Sent from my XT1585 using Tapatalk
Pacific Wheel
Reno, NV
It's the 250 center/center 3" muffler. I'm not certain on the tone without the resonator but I believe @Raptizzle has the same muffler without the resonator. He might be able to chime in on how it sounds.
Raptizzle
FYT
Southern CA
The resonator holds back the sound a bit in my opinion and I am very happy with the sound/tone without it. Also, the system seems to flow better by ditching the resonator too. You won't be disappointed!
Hopscotch
NW Ohio
Cool, thanks for the insight.
Now does anyone know how the race venom or widowmaker will sound?
level-4
SLO CA
I have the 250 as well with the stock exhaust and resonator delete, I had drone at 1800 rpm so I had a helmholtz resonator installed. Helped with the drone, still pretty loud.
Tango_9
I had a BW venom 250 installed Monday, replaced a magnaflow with it. The BW is definitely louder and has a deeper tone, I kept the resonator and tapped into the stock tail pipe. The magnaflow had a drone at highway speeds (75-80) but was tolerable, the BW is louder at highway speeds, not really a drone but louder and you can hear any movement of the gas pedal. Next project is sound dampened cab.
Hopscotch
NW Ohio
I'm contemplating changing out my Magnapak with a Black Widow...but need to choose between Widowmaker and Race Venom...so I'm curious also.
Anyone?
I went with the race venom. Can't speak on the widowmaker, but I really like the sound the race venom makes. It's a clean sound all the way through the RPMs and really sounds good wide open.
