Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 1]
VHF radio install pic's
This is a discussion on VHF radio install pic's within the Ford Raptor Audio/Video/Electronics Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Originally Posted by rkneeshaw Be prepared to be patient, and you're going to have to almost entirely dismantle your center ...
Like Tree197Likes
Old 05-17-2018, 08:36 AM   #361 (permalink)
Originally Posted by rkneeshaw View Post
Be prepared to be patient, and you're going to have to almost entirely dismantle your center console.
I had to remove the passenger seat (at least unbolt it and move it out of the way) so I could get enough slack in the carpet to run the antenna cable accross and up to the back of the console.
From there you'll have to remove the 2 8mm bolts near the bottom rear sides of the console so you can lift the console up about an inch or two, giving you enough room to get that large antenna connector routed up and in.
I chose to run my wiring right under the little media hub inside the console. That way the hole i cut will be really hard to see.
i also intend to use the aux in ports on that little media hub in there to pipe the audio from the radio into the built-in stereo system.
I also ran a small amount of cat5 forward to the front of the cup holders and I intend to put a RJ45 jack there on the side of the cupholders so the mic can plug in there.
Be prepared to bleed too :) my hands are all cut up.
But in the end, it will be real clean and OEM like.
awesome!, thank you for taking the time to help. Very much appreciated!
DEGBTI is offline   Reply With Quote
Old 05-26-2018, 09:06 PM   #362 (permalink)
rkneeshaw's Avatar
Completed the next phase of the install:
Used a panel mount RJ45 jack and a proclips mount for the mic. It clips into place, so no permanent drilling and i can remove it if I wont be using the radio for a while.
Ran the cat5 into the console for the radio
And mounted the 1/4 wave dual band antenna (Tram, from amazon)
I ordered a larsen NMOWB150B 1/2 wave for when I really need to reach out and touch someone
BenBB likes this.
2013 Ford SVT Raptor
Flutter Stacks - Fuel Offroad - Duratracs - Raptor Retrofit - Baja Designs - LineX
Build thread: http://www.fordraptorforum.com/f65/l...upercab-55911/
Wheelwell: 2013 Ford F-150
Fuelly: 2013 Ford SVT Raptor
rkneeshaw is offline   Reply With Quote
Old 06-01-2018, 05:04 PM   #363 (permalink)
rkneeshaw's Avatar
Finished up the radio install today.
This was tricky, getting these holes lined up. Its still not perfect but probably hard to tell. This is all you can see from outside the console, is two screw heads
And the radio is mounted inside.
BenBB likes this.
Old 08-09-2018, 12:56 AM   #364 (permalink)
jackrook's Avatar
Ok fellas. I’m mounting up my Icom F5021. I bought one unprogrammed on the cheap fro the bay. Bought the programming cd and have been researching. So I added the channels TO THE BEST OF MY ABILITY. Does anyone here have instructions or screenshots on how to program an Icom f5021? I have the cd and cable. But have no idea what I’m doing
A.D.D front Race Bumper with 20" LED bar, Stubby antenna, Mid perch, 37" Nitto Trail Grappler MTs, Icom F5021, Outlaw Raptor Alpha 1 bed rack, M&R v2 Hood Mounts, RPG Stage 2, stock exhaust resonator delete, M&R 50" radius roof bar, K&N air filter
Check out my build thread----->http://tinyurl.com/mhdrlma
slowest member of WCPR
jackrook is offline   Reply With Quote
Old 08-10-2018, 03:39 PM   #365 (permalink)
Wilson's Avatar
Originally Posted by jackrook View Post
Ok fellas. Iím mounting up my Icom F5021. I bought one unprogrammed on the cheap fro the bay. Bought the programming cd and have been researching. So I added the channels TO THE BEST OF MY ABILITY. Does anyone here have instructions or screenshots on how to program an Icom f5021? I have the cd and cable. But have no idea what Iím doing
try the one and only radio thread. I have it linked on the first post.
2018 calendar link >http://www.fordraptorforum.com/f16/2...ictures-54101/
Jeff Ethanol I use it
2012 #3105 Diablosport tune aFe stage 2 SW Headers Xpipe true duel S-type muffler 361rwhp
Wilson is offline   Reply With Quote
Tags
vhf radio
How To Nav Tv install and radio removal directions Icecobra Ford Raptor How-To's and FAQs 67 01-28-2017 10:33 PM
Kenwood ham radio install - Pic heavy KaiserM715 Ford Raptor Audio/Video/Electronics Forum [GEN 1] 29 05-27-2014 08:46 AM
VHF Radio install brd o pry Ford Raptor Audio/Video/Electronics Forum [GEN 1] 4 03-14-2013 04:23 PM
Help with ham radio install location jondle Ford Raptor Audio/Video/Electronics Forum [GEN 1] 10 07-24-2012 05:17 PM
Ham Radio Install BigJ Ford Raptor Audio/Video/Electronics Forum [GEN 1] 24 06-12-2012 06:02 PM
