Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 1]
VHF radio install pic's
This is a discussion on VHF radio install pic's within the Ford Raptor Audio/Video/Electronics Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Sweet, thanks, looks easy enough :)...
Like Tree195Likes
Old 10-11-2015, 02:58 PM   #351 (permalink)
Dutch451's Avatar
Dutch451 is offline   Reply With Quote
Old 11-15-2015, 11:11 AM   #352 (permalink)
All The Way's Avatar
75w FT-2900R YAESU $139.95
YAESU FT-2900R , YAESU FT2900R R&L Electronics
Wilson likes this.
All The Way is offline   Reply With Quote
Old 12-05-2015, 10:27 PM   #353 (permalink)
Dutch451's Avatar
Originally Posted by All The Way View Post
Not sure what happened with the video. http://youtu.be/SmZ8aU9dpL0
This winter if i have the time i want to get my extra.
Tested today and got my Technician license. Woohoo, now I can finally install all this stuff, lol. Unfortunately my laptop has been out for repair for a bit now, so I wasn't able to study the General material, but the examiner said I could come back within the year and take it and they won't charge me. Hopefully I can find a garage to use so I don't freeze my ass off running wires. I'll get pictures posted once everything is in.
Since I want to mount the face plate in the headliner, hopefully I can come up with a mounting plate that'll work where I can put a couple more switches in it for whatever.
Wilson likes this.
Old 12-05-2015, 10:52 PM   #354 (permalink)
Wilson's Avatar
You can use my garage if you wire mine or just use my garage
2018 calendar link >http://www.fordraptorforum.com/f16/2...ictures-54101/
Jeff Ethanol I use it
2012 #3105 Diablosport tune aFe stage 2 SW Headers Xpipe true duel S-type muffler 361rwhp
Wilson is offline   Reply With Quote
Old 12-06-2015, 09:54 AM   #355 (permalink)
The General test isn't to bad.. The Extra test is gonna be fun.
Old 05-06-2016, 10:59 AM   #356 (permalink)
srs's Avatar
srs
Originally Posted by Rookie View Post
It's actually very easy. The hardest part I had was fishing the antenna cable under the carpet. I purchased a cover for it that I use whenever I know I won't need my radio.
Attachment 52776Attachment 52777
Where did you get this from? Got a link? Thanks!
srs is offline   Reply With Quote
Old 05-08-2016, 06:42 PM   #357 (permalink)
Rookie's Avatar
Antenna Farm is usually where I order form.
http://www.theantennafarm.com/catalo...capb-3810.html
srs and Kmandoske like this.
Rookie is offline   Reply With Quote
Old 05-16-2018, 05:39 PM   #358 (permalink)
rkneeshaw's Avatar
Installed my antenna mount today, what a bitch that was. Getting under the carpet and into the console cleanly is a real challenge. But finally, after about 3 hours, I got it in.
Now I need to order a radio :)
And terminate my power and ground
And connect RJ45 jack to the side of the cupholders
Wilson and Trick_Raptor like this.
2013 Ford SVT Raptor
Flutter Stacks - Fuel Offroad - Duratracs - EvoX-R 2.0 - Baja Designs - LineX
Build thread: http://www.fordraptorforum.com/f65/l...upercab-55911/
Wheelwell: 2013 Ford F-150
Fuelly: 2013 Ford SVT Raptor
rkneeshaw is offline   Reply With Quote
Old 05-16-2018, 09:00 PM   #359 (permalink)
going to install my antenna mount friday. Same as yours. Any advice? going to my center console too. thanks
DEGBTI is offline   Reply With Quote
Old 05-16-2018, 10:27 PM   #360 (permalink)
rkneeshaw's Avatar
Be prepared to be patient, and you're going to have to almost entirely dismantle your center console.
I had to remove the passenger seat (at least unbolt it and move it out of the way) so I could get enough slack in the carpet to run the antenna cable accross and up to the back of the console.
From there you'll have to remove the 2 8mm bolts near the bottom rear sides of the console so you can lift the console up about an inch or two, giving you enough room to get that large antenna connector routed up and in.
I chose to run my wiring right under the little media hub inside the console. That way the hole i cut will be really hard to see.
i also intend to use the aux in ports on that little media hub in there to pipe the audio from the radio into the built-in stereo system.
I also ran a small amount of cat5 forward to the front of the cup holders and I intend to put a RJ45 jack there on the side of the cupholders so the mic can plug in there.
Be prepared to bleed too :) my hands are all cut up.
But in the end, it will be real clean and OEM like.
Tags
vhf radio
How To Nav Tv install and radio removal directions Icecobra Ford Raptor How-To's and FAQs 67 01-28-2017 10:33 PM
Kenwood ham radio install - Pic heavy KaiserM715 Ford Raptor Audio/Video/Electronics Forum [GEN 1] 29 05-27-2014 08:46 AM
VHF Radio install brd o pry Ford Raptor Audio/Video/Electronics Forum [GEN 1] 4 03-14-2013 04:23 PM
Help with ham radio install location jondle Ford Raptor Audio/Video/Electronics Forum [GEN 1] 10 07-24-2012 05:17 PM
Ham Radio Install BigJ Ford Raptor Audio/Video/Electronics Forum [GEN 1] 24 06-12-2012 06:02 PM
