Tweeters and crossovers
csirnak
Where are you guys mounting your crossovers for components in the front doors?
Also, I'm looking at running non amped JL C3-570 in the front. Do the tweeter wires connect from the front 5x7s, or do they go directly from the amp to the tweeter?
C
csirnak
you can put the crossovers under the front seat. the wires that come from the amp go to each individual speaker and are crossed over at the amp. i would connect the door woofers to the wires already there and only use the crossovers for the tweeters.. check here.
http://www.fordraptorforum.com/f12/your-raptors-audio-system-37480/
Thanks! So the wires from the tweeters run down the A pillars, but where can I access them to put the crossovers to them? Do they run down under the dash where I can easily access them, or are they buried behind the deck somewhere?
