Stock Front camera help??
Lincoln
I have a 2011 without the OEM Front facing Camera. I will be installing an aftermarket front camera from Alpine and I am looking at different mounting options. I purchased the license plate type mount with it, but I don't like the way that looks. Can someone with the stock set-up take a couple of close-up pics so I can compare? Also, do you think the stock mount can be retrofitted with an aftermarket camera, or will it be more work than its worth? How do you like the stock location and if you could, would you move it?
Thanks
NUTHINGOESRITE
Lincoln
Perfect. That is exactly what I was wanting to see. Good write-up too. Don't know why I didn't see that when I did my search.
