GEN 1 Smittybilt Connector for 35210/35220
McGrath4u
Anyone with experience of using separately purchased anderson connectors with the smittybilt 35210 or 35220 set?
I have successfully installed the 35210 set to the rear of the truck but I am trying to reuse the wiring that came with the winch with an anderson connector for the front of the truck instead of buying the entire 8' (35220) set for $80.
@BigBlue @RSiWORKS @anybodyelse
Amazon reviews show hit or miss with Warn provided connectors so there must not be a good standard.
Thanks guys.
M
McGrath4u
Found an Anderson or battery quick connector on Amazon.
X-Haibei Battery Quick Connector Kit 175A 2AWG Plug Connect Disconnect Winch Trailer https://www.amazon.com/dp/B00KXKW708/?tag=fordraptorforum-20
Worked well and fit with the original kit. For $20 I was able to reuse the cable that came with winch to provide a quick disconnect to the front of the truck.
I used the horn bracket as my location for the front and the hitch tube for the rear.
