Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 1]
Seeking GPS Advice/Suggestions
This is a discussion on Seeking GPS Advice/Suggestions within the Ford Raptor Audio/Video/Electronics Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Need to make a decision soonish. Which is the best way to mount a Lowrance GPS? -Ram adjustable mount -LGE/CTS ...
Like Tree1Likes
  • 1 Post By rap67
Old 09-24-2014, 01:12 PM   #1 (permalink)
Dan06's Avatar
Question Seeking GPS Advice/Suggestions
-LGE/CTS style folding mount
(This is what I'm leaning towards, but it was pointed out it will block some of the drivers vision. Does anyone have input?)
-OR any other ideas?
(It'll be custom regardless so any ideas you have are good ideas.)
I do want it to be accessible from the drivers seat.
Thanks
Dan06 is offline   Reply With Quote
Old 09-24-2014, 01:55 PM   #2 (permalink)
Bigg50's Avatar
I run the LGE/CTS mount and I'm very pleased with it. It does not obstruct my vision.
Expedition X Off-Road Team Member
website:www.expeditionxoffroad.com
facebook: www.facebook.com/expeditionxoffroad
build thread: http://tinyurl.com/nuh952x
instagram: @expeditionxoffroad
Bigg50 is offline   Reply With Quote
Old 09-24-2014, 02:12 PM   #3 (permalink)
I too have the LGE/CTS mount on a HDS 7 touch and I don't feel it blocks any vision. I don't really fold it down either as you need to disconnect the cables in order to fold it down on the HDS 7.
BABaracus is offline   Reply With Quote
Old 09-24-2014, 03:32 PM   #4 (permalink)
shooterAMG's Avatar
I built a "custom" RAM mount from their parts. I like that I can remove it easily. During Snoball pre-run and run, plus the Spring 14, it's never moved or fallen off. The suction cup keeps it in place and i have it rest on the dash.
shooterAMG is offline   Reply With Quote
Old 09-24-2014, 04:57 PM   #5 (permalink)
JayLV's Avatar
I got the Outlaw Offroad mount, we decided not to use it. Basically used the included mounting bracket and mounted it towards the front part of the speaker on the dash. It swivels so it can be used by the passenger or driver pretty easily.
2014 SCAB l Alpha 1 Berserker Front Kit l Fox 3.0s Rear l Deaver +2 l Alpha 1 Bumpstop Kit l Method 105 l 37x13.5x17 Toyo MT l Borla Type S
JayLV is offline   Reply With Quote
Old 09-24-2014, 05:03 PM   #6 (permalink)
rap67's Avatar
same,
BTW I have the HDS 7 touch and could not roll it back as advertised without smashing the cables and putting a lot of stress on the connection. so I took out the lower bolts, tighten the knobs so it doesn't move and when i need to roll it back i loosen it, pull the bottom out first and lay it down, then secure the knobs again.
i like it a lot.
Bigg50 likes this.
2014 White SCREW | matte silver wrap | ARB twin | Warn 9.5cti | Factor 55 Prolink | ADD bumpers | Rigid lights all around | Fuel trophy 18s with 35 Open Country RTs | Deaver +3s | SVC ABS bump stop | Camburg UCA and rear shackle | PSS reservoir | Alpha 1 bed cage & tie rods| VHF radio | Lowrance HDS 7touch | Viair tank | SVC Baja light tower | Fox 3.0 DSC | Fox 3.0 QAD | SVC tune | SW long tube headers | Corsa sport exhaust
rap67 is offline   Reply With Quote
Old 09-24-2014, 10:44 PM   #7 (permalink)
Dan06's Avatar
I'll probably do something in the folding mount style, since no one has negative comments. Someone just strongly stated it blocked the lower corner passenger side of the windshield, which made me second guess it. It'll be custom, so does anyone with the LGE/CTS mount have anything they wish could be changed or modified? More easily folded down is obviously one I assume. I also have a Lowrance 7 touch.
Old 09-24-2014, 11:16 PM   #8 (permalink)
rap67's Avatar
not off the cuff. Its a well thought out mount, sits in line with the NAV screen below it and I think makes the center stack look finished.
Old 09-24-2014, 11:39 PM   #9 (permalink)
Dan06's Avatar
Oh it appears to be a nice mount. Just the shop where the trucks at prefers not to use products they don't sell.
Tags
custom, gps, interior, lge/cts, lowrance
Seeking Radio Advice Dan06 Ford Raptor Audio/Video/Electronics Forum [GEN 1] 23 12-27-2015 03:44 AM
MONTANA - Helena Ranger District Seeking Public Comments on DEIS for Divide Travel Pl KaiserM715 Recreational Land Use Issues 0 03-19-2014 02:36 PM
Suggestions? jvanover04 Ford Raptor Lighting Modifications Forum [GEN 1] 2 03-15-2014 07:17 PM
