Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 1]
Radio/NAV Noob...
This is a discussion on Radio/NAV Noob... within the Ford Raptor Audio/Video/Electronics Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
I finally got around to ordering my Radio/NAV units for TRR. I know Nav isnt required but its recommended. Ill ...
Like Tree1Likes
Old 03-24-2014, 05:13 PM   #1 (permalink)
Raptor Embroidery's Avatar
aka Raptor_Al_41
Default Radio/NAV Noob...
I finally got around to ordering my Radio/NAV units for TRR. I know Nav isnt required but its recommended. Ill get in touch with Trey about a TRR map.
So I got the sweet LGE-CTS motorsports fold down mount and the Lowrance Elite 5M baja gps system with antenna to go with it. Just need a few pointers of uploading maps and how to use it efficiently.
Also I bought sonomas old Icom F-5021 radio. I have a mag mount for the antenna on the way. I think she has the presets programmed in. Just would like a few pointers and mounting/wiring locations. Thanks guys and look foward to getting some answers.
Stuff:
https://lge-ctsmotorsports.com/catal...raptors-detail
IC-F5021 Series VHF and UHF Transceivers - Features - Icom America
Elite-5m Baja - LOWRANCE | Marine Electronics
www.raptorcustomembroidery.com
Call/text - 256-599-6040 Email - [email protected]
Leather wrapped center consoles, embroidery and laser engraving.
Raptor Embroidery is offline   Reply With Quote
Old 03-25-2014, 03:02 AM   #2 (permalink)
aka Raptor_Al_41
Anybody? Any places you guys want to point me towards?
Old 03-25-2014, 08:37 AM   #3 (permalink)
JJ f150harley's Avatar
Here's how I did my CB. I used a 1x1 piece of aluminum from home depot and cut it to be the same length of the u bracket that came with the radio. Then I used 4 2inss bolts and lock nuts to go through the u the aluminum and through the plastic tray. Then I put a thin wide piece of aluminum under the plastic to support it all. In the back I drilled a 3/4 in hole using a drill bit, use a whole saw or a full drill bit not any of the wood ones with the flat head. I ran the wires down the pass side under the air bag and did a fuse tap to wire it. And I grounded it there too. Works really nice and I made it so if I want to take it off I can just put the mat back on and it covers up everything. Oh and my factory speaker still works there be as use I went above it and didn't buy a new tray to put it in.
Sent from my DROID RAZR HD using Tapatalk
uploadfromtaptalk1395750658577.jpg   uploadfromtaptalk1395750677833.jpg   uploadfromtaptalk1395750692699.jpg
JJ f150harley is offline   Reply With Quote
Old 03-25-2014, 03:33 PM   #4 (permalink)
aka Raptor_Al_41
Looks great! But the mount for my GPS will have to go there unfortunately... If anyone had any other radio mounting location ideas, thatd be great!
Old 03-25-2014, 03:37 PM   #5 (permalink)
MajorAR's Avatar
Stuff:
Why did you go with the Baja? Isn't it discontinued?
Also, there is an entire thread on Radio mounting and etc...
[email protected]
Sales
(866) 691-7750
MajorAR is offline   Reply With Quote
Old 03-25-2014, 03:38 PM   #6 (permalink)
aka Raptor_Al_41
I've heard a lot of good things about it. And yes it was discontinued. If need be I could swap it and the mount for a better one?
Old 03-25-2014, 03:42 PM   #7 (permalink)
MajorAR's Avatar
---------- Post added at 07:42 PM ---------- Previous post was at 07:41 PM ----------
---------- Post added at 07:42 PM ---------- Previous post was at 07:42 PM ----------
[email protected]
Sales
(866) 691-7750
Old 03-25-2014, 03:45 PM   #8 (permalink)
aka Raptor_Al_41
Great mounting location!! What about coax/antenna
Old 03-25-2014, 03:49 PM   #9 (permalink)
MajorAR's Avatar
I drilled a hole JUST large enough to fit the power connector through, and then ran the power wire underneath the flooring to the fire wall. You'll find an opening up under the dash and on the firewall. Remove the rubber plug and route your power wire to the battery itself. Use zip ties as required.
---------- Post added at 07:49 PM ---------- Previous post was at 07:48 PM ----------
The antenna coax is nothing sexy. I have weathertech rear mats, so ran the antenna wire underneath the floor mat, underneath the seat and then I stash the magnetic antenna mount behind the seat until I'm ready to hit the desert. Then i just crack my slider and run the magnetic mount and up onto the top of my cab. Done deal. It's def not rocket science. I unplug the mike from the radio and stash the antenna behind the seat when not in the desert.
[email protected]
Sales
(866) 691-7750
Old 03-25-2014, 03:51 PM   #10 (permalink)
The Car Stereo Company's Avatar
aka nosbusa
i am working on a mount for my gps unit, however it will not be ready for trr. i was hoping to test it out while i was there, but fabrication has taken longer than i had hoped. as for the radio, i am disconnecting the face, extending the ribbon cable and putting the face in my sunglass holder. i dont use that spot for anything so i figure its a perfect location. after the wiring mod. that will not be fun
its not how fast you can go......its how fast can you get to fast......
The Car Stereo Company is offline   Reply With Quote
Tags
coax, gps, icom, lowrance, radio
Noob from Phx AZ burlybear New Member Check-In 16 03-10-2014 04:47 PM
Noob! Evilmonkey New Member Check-In 13 03-12-2013 01:14 AM
Noob from OKC Night_Stalker New Member Check-In 11 02-15-2013 09:51 PM
New New Noob Noob roadman New Member Check-In 8 06-23-2011 12:59 AM
Ham Radio Communication - Ham Radio MagicMtnDan Ford Raptor Audio/Video/Electronics Forum [GEN 1] 10 10-13-2010 12:19 PM
