Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > GEN 1 (2010-2014) Ford SVT Raptor Forums > Ford Raptor Audio/Video/Electronics Forum [GEN 1]
Installing aftermarket horns??????????
This is a discussion on Installing aftermarket horns?????????? within the Ford Raptor Audio/Video/Electronics Forum [GEN 1] forums, part of the GEN 1 (2010-2014) Ford SVT Raptor Forums category!
Did a search but really didn't get my question answered as I had hoped. OK...so here is what I want ...
Like Tree8Likes
Old 11-25-2014, 09:56 AM   #1 (permalink)
Popcorn Installing aftermarket horns??????????
Did a search but really didn't get my question answered as I had hoped. OK...so here is what I want to do. I have purchased these horns:
Amazon.com: Viking Horns V621K Dual Trumpet Train Air Horn: Automotive Amazon.com: Viking Horns V621K Dual Trumpet Train Air Horn: Automotive
Another information site:
https://www.superiorhorns.com/air-ho...mpressors.html
I want to "T" connect them into the stock horn wires so when I hit the horn all four will blow. I can do a brake job in one hour but wiring and electricity are beyond me to understand. Hell, I don't even know where the horn fuse is located, which I may have to change as well. I have a volt meter so I have enough sense to tell hot wire from ground but kit comes with a relay and of course I have no idea how I wire that. I have gotten plenty of great advice from you folks so I am hoping that you folks can come to my rescue. I will have enough of a challenge to figure out how to mount these horns but that I think I can handle. I just am not sure how to do the wiring and do I need a larger fuse etc. Any help would be greatly appreciated.
LEADING AMERICA FROM THE BACK OF THE LINE
mudblood is offline   Reply With Quote
Old 11-25-2014, 10:21 AM   #2 (permalink)
Yukon Joe's Avatar
Do you want them to be active ask the time or do you want a toggle switch to turn them off?
Donate to Avery and be entered into a raffle for an awesome prize for your Raptor
November Pay It Forward Event!
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 11-25-2014, 10:24 AM   #3 (permalink)
I want them active all the time. Hence the reason I would "T" them into stock horn wires. Keep in mind these are simple 12v horns with small compressors that run off 12v. I had one in my old truck but a friend wired it for me and he is no longer available to help.
Old 11-25-2014, 10:29 AM   #4 (permalink)
Yukon Joe's Avatar
You'll tap into the hot wire right at the horn under the hood. I think it's yellow. You'll need the relay to run those little compressors.
I always put up the @The Car Stereo Company bat symbol.
I love Raptorwifey
Old 11-25-2014, 03:35 PM   #5 (permalink)
Thanks Joe. How about the ground wire? Do I not hook into that as well? How about the horn fuse...will it not need to be larger? By the way....where is the horn fuse in our trucks? See I told you I was a dumbass about "LECTRICTY"!
Old 11-25-2014, 05:08 PM   #6 (permalink)
You will use the Horn Positive wire to trip the relay for the new horns. You will need to run power for the new horns utilizing the relay. SO the negative on the new horns just needs to be grounded to the truck and then you can run a new power connection with a fuse from the battery to the relay. Then run from the relay to the new horns positive. The relay is tripped when your original horns go on and that powers up the new horns.
2014 Terrain SCREW -
It's turning into a Mutt..
SilentShooter is offline   Reply With Quote
Old 11-25-2014, 05:22 PM   #7 (permalink)
cups's Avatar
If I may interlope for a moment: question of where the fuse is for OEM horns is buried in this thread. I want to know this also but haven't found it yet. Any help here?
cups is offline   Reply With Quote
Old 11-25-2014, 05:29 PM   #8 (permalink)
http://www.fordservicecontent.com/Fo.../13f12om3e.pdf
Looks at page 316 or open your manual. No one should ever need to ask where a fuse is. Every fuse/relay is in the manual with a diagram and exact location
cups likes this.
Old 11-25-2014, 06:48 PM   #9 (permalink)
cups's Avatar
Thanks SShooter. Don't know why I didn't see that, should have been the 1st placed I looked. So now I'm one step closer to actually completing a mod.
Not sure if my mod would be considered appropriate in your thread. Same idea, different path. So I'll post details in a new thread. But thanks for bring it up.
I'm replacing the stock horns with (hopefully) more Raptor worthy ones. Just a direct replacement.
dataustin and AbnMP13 like this.
Old 11-26-2014, 09:08 AM   #10 (permalink)
Yukon Joe's Avatar
You don't need to mess with the stock horn fuse. Don't worry, I hate wiring as well.
I refer to this diagram at times. Replace the worth "lights" with "horn."
dataustin likes this.
I love Raptorwifey
Train horns mrpork Ford Raptor Exterior Modifications Forum [GEN 1] 56 11-24-2014 01:02 PM
Train Horns - loud horns - aftermarket horns mudblood Ford Raptor Exterior Modifications Forum [GEN 1] 29 11-20-2014 02:13 PM
Frame horns BrockMarcotte Want to Buy 8 05-10-2014 02:59 AM
Loud horns CLAMUP Ford Raptor Exterior Modifications Forum [GEN 1] 23 12-14-2012 02:36 PM
Help- Installing aftermarket horn xBX Ford Raptor Exterior Modifications Forum [GEN 1] 9 03-23-2011 11:41 AM
