Front Camera Stopped Working
Skyfrog
Brandon, FL
I've been using the front camera / NAV-TV combination for a long time now. It is especially useful when pulling up to a pole or wall when parking.
Without any changes or incidents, the camera simply stopped working. I try the NAV-TV method and the standard Ford methods, but it simply goes to the "how to activate camera" screen, i.e. "disabled". The NAV-TV is still working with the reverse camera.
I tried re-seating the connector at the camera, but that did not help. Beyond that, I'm not sure how to diagnose the problem. Do the cameras occasionally die unexpected or am I looking at a connection issue?
I'm still under extended warranty, but I'm not sure how Ford service would react with the NAV-TV installed.
Any ideas on how to further diagnose the problem? I was going to simply buy one off of EBay to try, but dang they are expensive.
BenBB
Lots of different places
I'm not sure but if it was mine I'd want to rule out any broken wiring first before shelling out for camera or BCM or whatever. Doesn't take much to pinch/cut/break a wire and can cause all kinds of gremlins, especially when hidden in a harness or connector...
Raptized
Raptorida
Did you get this working? Mine was a wiring harness unplugged under the center console on the back of the "Off road mode" button.
Skyfrog
Skyfrog
Brandon, FL
Partially working...
I took it to the dealer for a radiator leak (under warranty) and told them the camera also went out. When I got it back, they had replaced the front camera worked great, ONLY IN REVERSE.
I tried a few things, but I'm not done diagnosing it yet. I figured the dealer would not touch it if I told them the NAV-TV was installed. One thing that worked was unplugging the front camera. Now the rear camera works in reverse, which I need every day to park.
I'll update when I know more.
Raptized
Raptorida
Does it work normally if you disconnect the nav-tv?
aka grumpy car stereo guy
I haven't tried that yet. It may be difficult as the install required taking the dash apart.
the cables are long enough that you can relocate them to the bottom. on the drivers side panel theres 1 7mm bolt by the gas pedal and the cover comes off. every one i have installed i have put down there for ease of access. you may want to do the same so if there are any future problems you can get to it easy
Skyfrog
Skyfrog
Brandon, FL
It's been a while, but I finally got my front camera working today...
I tried Noah's suggestion to reset the NavTV's cables, which were located where he suggested, huh, I must have watched his video. :smiley-face-popcorn but resetting did not help.
However, I was OK for awhile with the front camera disconnected as long as the rear camera worked in reverse.
Last time it was in the shop, I had them check it out again. It seems it was throwing a "Steering Wheel Sensor" fault code. I did notice the directions lines were acting up, but didn't think it was related. Apparently it was. After they replaced the sensor (and housing?), the NavTV worked correctly again, including the normal Ford functions.
I'm glad to have it back again so I can sneak up on parked cars. And for those thinking about Extended Warranty, I think it finally paid for itself:
  • Front passenger window motor replaced
  • Rear sliding window working again
  • Radiator hose leak fixed
  • Front camera replaced
  • Steering wheel sensor replaced
